How to Enable GST-IMX Plugins for Android 9 on i.MX 8M Mini.
1,679 次查看
sambasiva_kurak
Is there a page similar to https://community.nxp.com/docs/DOC-93387 for IMX8M Mini.
We are trying to compile GStreamer(along with Good, Bad, Base and imx-gst-plugins pulled from codeaurora) for i.MX 8M Mini EVK Android 9. Please let us know how to enable all the IMX GST Plugins. Build output shows certain features like “vpu_wrap” are disabled which are required for video decoding using GST in Android 9 environment. We tried setting “--enable-vpuwrap” in config options but still the features are not enabled.
Configure result:
        Enabled features:
                plugin: v4lsink
                libs: v4l2core
        Disabled features:
                plugin: imxmp3enc
                plugin: wma8_enc
                plugin: vpu_wrap
                plugin: aiur
                plugin: beep
                plugin: overlaysink
                library: libX11
                imx2ddevice: g2d
                imx2ddevice: ipu
                imx2ddevice: pxp
标记 (2)
1,420 次查看
joanxie
if you need install vpu_wrap, pls try to use the commands as below:
bitbake -c compile -f imx-vpuwrap
bitbake -c install -f imx-vpuwrap
