How to Add Mipi-DSI display
4,356 次查看
w_colmenarez
Hello.
I'm trying to make work a Mipi-DSI display with a iMX6Q without success.
Do someone know about this or where can I find information?
Thanks!
3,617 次查看
igorpadykov
Hi Walmore
one can look at description of mipi-lcd drivers in sect.6.4.2.2 Source Code Structure
attached Linux Manual and adjust lcd timings in
struct fb_videomode truly_lcd_modedb[] in linux/drivers/video/fbdev/mxc/mxcfb_hx8369_wvga.c
mxcfb_hx8369_wvga.c\mxc\fbdev\video\drivers - linux-imx - i.MX Linux kernel
use appropriate kernel boot parameter for that lcd, as described in Table 11. Common kernel boot
parameters attached Release Notes.
