HI :
we use ms6q_sabresd board as a platform to development . we need the board output the display data format is 20-bit YCbCr .
Then i read kernel and uboot code .and only find the code what is support HDMI LVDS and RGB format . what i shoud do ?
Thanks anyway!
已解决! 转到解答。
Please check the Linux Release notes table 6. the video section. If the format you want doesn't works in setting by kernel boot parameter. I'm afraid you will have to add it in the kernel or driver.
Michel
Michel
