Hello everyone, the board I use is MCIMX7SABRE. I only soldered the nor flash chip MX25L51245G on my board. So I want to burn the image into the nor flash. I am using MFG Tools L4.1.15_2.1.0. I used three methods: First, I started MfgTool2.exe directly, the program prompts in the partition, but the program seems to be stuck here. Second, I modified [LIST] name = Quad Nor Flash in cfg.ini. In this way, the program MfgTool2.exe can not be started, prompting an error. Third, I directly start mfgtool2-yocto-mx-sabresd-qspi-nor-mx25l51245g.vbs. In this way, the program will fail when the partition is erased.
My BOOT MODE is set to: Serial Downloader
I hope everyone can help me.
