How do I stream my camera using RTSP in Gstreamer on SABRESD
2,609 次查看
mehdisarkeshi
I have searched all over the internet with no luck. I am trying to create a RTSP stream (TCP) from my SABRESD board to a Wowza server.  I have been able to create a UDP/RTP stream using the Linux guide but I can't create a RTSP stream as there is no rtspsink element. Any help is appreciated:
标签 (5)
标记 (3)
1,962 次查看
Hi Mehdi
one can check document ov5642-mx6qsdp-stream.pdf on
1,962 次查看
mehdisarkeshi
Thanks Igor,
I tried this but the other end (wowza) did not recognize this as an RTSP stream. With tcpserver, I could only make it work with tcpclient sitting at the other end.
1,962 次查看
harshal_patel
Hey,
I am trying to do the exact same thing. Want to stream my camera display to WOWZA through RTSP.
Did you find a solution to your problem?
Thanks.
