How can we interface a Smart Card with iMX6 DualLite processor?
1,752 次查看
admin
Specialist II
My Smart  Card on one side interfaces the card and on the other side it interfaces the processor. Clock, I/O and reset signal are supposed to come from the processor. Now to which exact pin it has to be connected with processor?
标签 (6)
标记 (2)
1,535 次查看
MehmetAliIpin
Contributor V
Dear Vinit,
It depends which smart card phy chip you are using, but at least to select the operaing voltage of 1.8,3.3, or 5 Volts, you need to add two more IO pins. If you write your phy chip, I will try to help you.
Mehmet Ali Ipin
