How can i display frame of mipi camera on frame buffer?
1,042 次查看
21300466
Hi,  i'm trying to find the way to receive frame from mipi camera and display it on frame buffer in imx6 duallite sabresd board.
How can i receive frame from MIPI camera? Should i use ioctl or is there any package(then how can i build images in yocto)?
Thank you.
标签 (2)
981 次查看
joanxie
when you connect mipi to imx6 board, you couldn't get frame? if yes, pls refer to the document which tell you how to debug mipi :
https://community.nxp.com/docs/DOC-339925
