How can i access unaligned address in i.mx8m mini
Hariharan1
I am trying to read
uint32_t *adr = (uint32_t*)0x42000001 (ddr address)
i can't read adr value. what is the issue.
the same variable i was reading in uboot code there is working properly. anyone can suggest the answer.
Thanks.
Manuel_Salas
You can try to use memtool to this propose. /unit_test/memtool in linux BSP.
Salas.
Hariharan1
Those file were not used in uboot still  were working. what does it make change in makefile
