How can I get an IP address?
lei_zhang1
android_N7.1.2_2.0.0_image_6dqpsabresd
IMX6q
There is no dhcpdc in /system/bin, then how can I get an IP address?
joanxie
if you couldn't see the ipaddress when you use command ifconfig, then you can set it by yourself, use the command, "sudo ifconfig eth0 x.x.x.x“,then you can use ifconfig to check it again.
joanxie
