How can I change debug port to other UART on i.mx8qxp MEK ?
2,501 次查看
chen_jackcw
Hi all,
After doing factory reset (erase all data) under Android, reboot the mek. USB debug port can't work. Is there any one meet this kind of issue ?
I don't know how to recover it, and I want to change debug port from debug usb port to RS232 port on base board.
Is there any one know how to change debug port from debug-USB to RS232 port ?
Jack
2,333 次查看
Hi Jack
one can try to reflash image with Demo Images – i.MX 8QXPlus MEK and Tool on the link
Alpha / Beta BSPs for Microprocessors|NXP
Note i.MX8QXP is not publicly released yet and so not fully supported,
in general uart port initialization codes can be found on
uboot/board/freescale/imx8qxp_mek/imx8qxp_mek.c
https://source.codeaurora.org/external/imx/uboot-imx/tree/board/freescale/imx8qxp_mek/imx8qxp_mek.c?...
4 回复数
2,334 次查看
Hi Jack
2,333 次查看
chen_jackcw
Hi igor,
Thanks for your support. BTW is there any document to describe how to do BSP porting on i.MX 8QXPlus MEK.
Jack
2,333 次查看
Hi Jack
one can check Porting Guide document included in linux documentation package on
2,333 次查看
chen_jackcw
Hi igor,
Thanks for your info., I will check it in Linux documentation package.
Jack
