How To implement New command in u-boot
5,201 次查看
nagaprasadvasam
Hi everyone,
                     I am using imx6ulevk board, i need to add one new command to u-boot boot loader,how can i add new command can any one help me.i searched for information but not found anywhere,if any one has information regarding this please send details or links.
Thanks & Regards,
Prasad.
标签 (3)
5 回复数
4,077 次查看
joanxie
what kind of command do you need to add? add new output ?
4,077 次查看
nagaprasadvasam
   Thanks For your reply for my question,so I need a commad like for example if i enter that command i need to print "hello world welcome to u-boot" like some message .please
   help me with some inputs.
Thanks & Regards,
  Prasad.
4,077 次查看
kishore_k
hi,
i need to add a command . Do u get the answer for that command creation.If u got please share the procedure to create command.
Thank you.
4,077 次查看
joanxie
it seems that you need execute a program like hello world, I suggest that you write a c code added in the bsp, compile it with toolchain, when board boot up, you execute this program to get what you need,
https://community.nxp.com/docs/DOC-95333
4,077 次查看
joanxie
if you need build your own application file, pls refer to the training as below
Task #8 - Build kernel manually using created toolchain
