How Can I Enable AER(Advanced Error Reporting) drivers when PCIe is configured as Endpoint
2,784 次查看
mallibeerala
How Can I Enable AER(Advanced Error Reporting) drivers when PCIe is configured as Endpoint.
Thanks & Regards,
Mallikarjuna B.
2,767 次查看
Dhruvit
Hi @mallibeerala,
I hope you are doing well.
One can refer to below-mentioned documents for more information.
The PCI Express Advanced Error Reporting Driver Guide
PCIe Advanced Error Reporting User Manual
Thanks & Regards,
Dhruvit Vasavada
2,754 次查看
mallibeerala
Hi Dhruvit,
In these documents drivers are related pcie root complex but not available for pcie endpoint.
I want AER drivers for PCIe endpoint.
Thanks & Regards,
Mallikarjuna B.
2,705 次查看
Dhruvit
Hi @mallibeerala,
AER driver only attaches root ports that support PCI-Express AER
capability.
Any Documents or driver related to AER for Endpoint is not available yet.
Thanks & Regards,
Dhruvit Vasavada
