Hi could you share the reference implmentation/ configuration for imx8m ECSPI with DMA support.
1,703 次查看
Venkat21
Looking for a reference implementation/ configuration support for imx8m ECSPI with DMA support. Also need to access SPI DMA tx rx data from user space.
1 回复
1,694 次查看
weidong_sun
 SPI driver (spi-imx.c) already uses sdma transmission, you don't need to consider using sdma in user space.
see drivers/spi/spi-imx.c, please!
#define DRIVER_NAME "spi_imx"
static bool use_dma = true;
module_param(use_dma, bool, 0644);
MODULE_PARM_DESC(use_dma, "Enable usage of DMA when available (default)");
Have a nice day!
B.R,
Weidong
