Hello, I currently just purchased an imx6q board and I'm trying to put Android 5.0.0 on it. I'm running into some difficulties trying to partition the SD card. When I run the mksdcard-android.sh on my SD card, I get the following errors ( I've made sure the card is unmounted (umount /dev/sdc) before I run the script):
1+0 records in
1+0 records out
1024 bytes (1.0 kB) copied, 0.000188717 s, 5.4 MB/s
Checking that no-one is using this disk right now ...
BLKRRPART: Device or resource busy
This disk is currently in use - repartitioning is probably a bad idea.
Umount all file systems, and swapoff all swap partitions on this disk.
Use the --no-reread flag to suppress this check.
Disk /dev/sdc: 29476 cylinders, 64 heads, 32 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/sdc: unrecognized partition table type
Old situation:
No partitions found
Warning: given size (28412) exceeds max allowable size (28372)
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End MiB #blocks Id System
/dev/sdc1 0+ 15 16- 16383+ 83 Linux
/dev/sdc2 16 23 8 8192 83 Linux
/dev/sdc3 24 1103 1080 1105920 5 Extended
/dev/sdc4 1104 29515 28412 29093888 83 Linux
/dev/sdc5 24+ 535 512- 524287+ 83 Linux
/dev/sdc6 536+ 1047 512- 524287+ 83 Linux
/dev/sdc7 1048+ 1055 8- 8191+ 83 Linux
/dev/sdc8 1056+ 1061 6- 6143+ 83 Linux
/dev/sdc9 1062+ 1063 2- 2047+ 83 Linux
Warning: partition 4 extends past end of disk
Successfully wrote the new partition table
Re-reading the partition table ...
The command to re-read the partition table failed.
Run partprobe(8), kpartx(8) or reboot your system now,
before using mkfs
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
Old situation:
New situation:
/dev/sdc1 8 15 8 8192 83 Linux
before using mkfs
(See fdisk(8).)
Any thoughts?
