HSIC designguide
HSIC designguide
martinneumaier
Hi all
Is there a design-guide for HSIC use with iMX6?
What is the recommended NVCC_RGMII voltage for HSIC?
We are trying to use a Microchip LAN9730 but the HSIC bus stays Idle and the controller is not recognized
Rita_Wang
Hi Martin,
About the design for HSIC use with iMX6 you can refer to http://cache.freescale.com/files/32bit/doc/app_note/AN4589.pdf?fpsp=1&WT_TYPE=Application%20Notes&WT....
And the setting of NVCC_RGMII voltage you'd better to check it in i.mx6 Reference Manual.
Hope this can help you. Have a great day~~
Best Regards
Dan
