HABv4 and certificate expiring date
1,594 次查看
antonio_santagi
I have read https://community.nxp.com/thread/478331
but since I cannot read correctly the question, just to make sure I ask specifically for iMX8M mini and HABv4.
Does that mean that HAB will verify successfully and load a signed image by using a correspondent certificate, even if it has already expired ?
Or can CST tool generate new certificates reusing same keys when previous certificates expire?
thank you
标记 (2)
1,528 次查看
Yuri
   Yes,  HAB will verify successfully and load a signed image by using a correspondent certificate,
even if it has already expired. CST tool cannot generate new certificates, reusing same keys, when
previous certificates expired.
Yuri.
1,529 次查看
Yuri
Yuri.
