HAB v4 API from Linux
2,623 次查看
antonio_santagi
I read that it is possible from U-Boot to use  HABv4 APIs on iMX8M Mini to authenticate a Kernel image or other file.
Is it possible to use same HABv4 APIs from Linux user space to authenticate/ verify signed files ?
Is it possible to reuse code from NXP on U-BOOT for this or is it needed to rewrite it for some reason ?
thank you
标记 (2)
2,549 次查看
Yuri
   HAB API is based on i.MX boot ROM codes and there is no support for it under Linux.
Also, the following may be useful:
Verify signed images from Linux user space
Yuri.
