H.264 encode delay time.
1,739 次查看
takashitakahash
Hi community.
Our costomer has delay time question.
About the H.264 encoding  General delay is  2 frame necessary i heared.
What is correct encode delay time of 720 p 30 fps of H.264 CBP ?
1,694 次查看
igorpadykov
Hi Takashi
the delays in the encode path are not characterized for VPU. Generally
different streams have different delayed frames (up to about 16 frames
according to H.264 spec).
1,695 次查看
igorpadykov
Hi Takashi
