Hi All,
We download FSL Community BSP source code as below:
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b fido
and execute gstreamer for camera capture.
Our command as below:
gst-launch-1.0 imxv4l2src device=/dev/video1 ! 'video/x-raw, format=(string)NV12, width=1920, height=1080, framerate=(fraction)60/1' ! imxvideoconvert_g2d rotation=3 ! video/x-raw,format=RGB16,width=1080,height=1920 ! autovideosink &
However, gstreamer will be stuck.
The log as below:
root@imx6qsabresd:~# WARNING: erroneous pipeline: could not link imxv4l2videosrc0 to imxvideoconvert_g2d0
^C
[1]+ Done(1) gst-launch-1.0 imxv4l2videosrc device=/dev/video1 ! 'video/x-raw, format=(sk
utovideosink &d rotation=3 ! video/x-raw,format=RGB16,width=1080,height=1920 ! a
[1] 462
root@imx6qsabresd:~# mxc_v4l_open 1627
mxc_v4l_open 1639
ERROR: v4l2 capture: slave not found!
mxc_v4l_open 1627
mxc_v4l_open 1756
Setting mclk to 24 MHz
ioctl_dev_init 3331
ARRAY_SIZE(ov5640_mode_info_data) 2
====== IMXV4L2SRC: 4.0.3 build on Nov 19 2015 20:53:47. ======
Setting pipeline to PAUSED ...
display(/dev/fb0) resolution is (1200x1920).
set color key:00010mxc_v4l2_output v4l2_out.32: Bypass IC.
203
====== OVERLAYSINK: 4.0.3 bumxc_v4l2_output v4l2_out.32: Bypass IC.
ild on Nov 19 2015 20:53:49. ======
Attempt to unlock mutex that was not locked
Have any one know what is happen?
Yao
