Gstreamer command convert to gst-python
ソリューションへジャンプ
6,122件の閲覧回数
thepnimit
Hi NXP team,
We are use gstreamer on IMX8QX for stream multi camera with command pipeline
gst-launch-1.0 -v imxcompositor_g2d name=comp \
sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=240 \
sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=240 \
! v4l2jpegenc ! rtpjpegpay ! udpsink host=192.168.60.255 port=5000 \
v4l2src device=/dev/video3 ! "image/jpeg, width=3264, height=2448" \
! v4l2jpegdec ! imxvideoconvert_g2d \
! capsfilter caps="video/x-raw, width=320, height=240, pixel-aspect-ratio=1/1" ! comp.sink_0 \
v4l2src device=/dev/video5 ! "image/jpeg, width=3264, height=2448" \
! capsfilter caps="video/x-raw, width=320, height=240, pixel-aspect-ratio=1/1" ! comp.sink_1
This's command hasn't problem when run on shell, But when we need to develop in python code
Normally have function
Gst.parse_launch() for convert command pipeline to variable e.g.
スポイラ
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
Gst.init(None)
_pipeline = Gst.parse_launch("""v4l2src device=/dev/video3 !
image/jpeg, width=3264, height=2448 ! fakesink""")
The problem is we cann't convert top command to pipeline
スポイラ
_pipeline = Gst.parse_launch("""imxcompositor_g2d name=comp
! capsfilter caps="video/x-raw, width=320, height=240, pixel-aspect-ratio=1/1" ! comp.sink_1""")
(python:27527): GStreamer-CRITICAL **: 17:32:04.929: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
(python:27527): GStreamer-CRITICAL **: 17:32:05.081: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
gi.repository.GLib.Error: gst_parse_error: syntax error (0)
Do you have suggestion or how to convert pipeline command to python variable or not?
Thepnimit
6,107件の閲覧回数
thepnimit
Thank for suggest
Now we are found solution for streaming, The " (double quote) after source pipeline is main problem when delete, it's work
Thepnimit
2 返答(返信)
6,114件の閲覧回数
b36401
6,108件の閲覧回数
thepnimit
Thank for suggest
Thepnimit
