Gstreamer Accelerated Decoding example in C?
3,067件の閲覧回数
Tarek
Senior Contributor I
Is there any examples in C language on how to use gst-fsl API's for accelerated video decoding?
ラベル(4)
2,527件の閲覧回数
rogerio_silva
Hi Tarek,
You can take a look on this page: https://community.freescale.com/docs/DOC-1378
Rgds
Rogerio
3 返答(返信)
2,528件の閲覧回数
rogerio_silva
Hi Tarek,
Rgds
Rogerio
2,527件の閲覧回数
Tarek
I have compiled the given application and got the following problem:
(playvideo:2088): GLib-GObject-WARNING **: g_object_set_valist: object class `GstVpuDec' has no property named `codec-type'
The gstreamer command line is working fine so I think all I need is to add the correct element.
Any suggestions will be much appreciated.
Rgrds,
Tarek
2,527件の閲覧回数
rogerio_silva
Seems that the string "codec-type" is not being recognized as a property name of some plugin.
You can check the available properties and their options by using:
gst-inspect <plugin name>
Rgds
Rogerio
