Get error when importing an SDK for imx8
1,052件の閲覧回数
bmc
I've created an SDK online for the iMX8QM  MIMX8QM6xxxFF target.
When I drag the downloaded SDK into MCUXpresso IDE I get an error.
Here is the error log:
[/home/xxxx/Downloads/SDK_2.9.0_MIMX8QM6xxxFF.tar.gz]
!SESSION 2021-03-08 08:50:04.962 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_265
java.vendor=AdoptOpenJDK
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.jface 2 0 2021-03-08 08:50:21.539
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2021-03-08 08:50:21.539
!MESSAGE A conflict occurred for ALT+CTRL+SHIFT+L:
Binding(ALT+CTRL+SHIFT+L,
ParameterizedCommand(Command(com.nxp.mcuxpresso.core.debug.linkserver.ui.CRTCApplicationLaunchShortcut,MCUXpresso IDE LinkServer (inc. CMSIS-DAP) probes,
Category(org.eclipse.core.commands.categories.autogenerated,Uncategorized,Commands that were either auto-generated or have no category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2b4954a4,
[Parameter(com.nxp.mcuxpresso.core.debug.support.shortcut.parameter,parameter,null,true)],,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.text.quicksearch.commands.quicksearchCommand,Quick Search,
Category(org.eclipse.text.quicksearch.commands.category,Quick Search,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2f2f92f,
,,true),null),
!MESSAGE A conflict occurred for CTRL+U:
Binding(CTRL+U,
ParameterizedCommand(Command(com.nxp.swtools.clocks.commands.unlockAll,Unlock All Settings,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@cfc4601,
,,true),null),
Binding(CTRL+U,
ParameterizedCommand(Command(org.eclipse.jdt.debug.ui.commands.Execute,Execute,
Evaluate selected text,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@240291d9,
,,true),null),
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2021-03-08 08:50:25.073
!MESSAGE Recreating part support. No part support available.
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 -1 2021-03-08 08:51:00.696
!MESSAGE The SDK 'SDK_2.x_MIMX8MQ5xxxHZ' does not contain any MCUXpresso IDE compatible toolchain.
!STACK 0
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.addToMap(SDKManifestProvider.java:893)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.access$0(SDKManifestProvider.java:871)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider$2.visitFile(SDKManifestProvider.java:669)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider$2.visitFile(SDKManifestProvider.java:1)
at java.nio.file.Files.walkFileTree(Files.java:2670)
at java.nio.file.Files.walkFileTree(Files.java:2742)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKManifestProvider.refresh(SDKManifestProvider.java:634)
at com.nxp.mcuxpresso.core.datamodels.SDKChipVendorDatabase.refresh(SDKChipVendorDatabase.java:803)
at com.nxp.mcuxpresso.core.datamodels.SDKChipVendorDatabase$1.run(SDKChipVendorDatabase.java:364)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 -1 2021-03-08 08:51:01.843
!STACK 0
at com.nxp.mcuxpresso.core.datamodels.ui.views.SDKView.doRefresh(SDKView.java:1751)
at com.nxp.mcuxpresso.core.datamodels.ui.views.SDKView$1.run(SDKView.java:419)
 Any idea what the problem could be?
Solved: The problem turned out to be selecting "GCC" for the Required Toolchains when I should have selected "MCUXpresso IDE" when building the SDK online.
1,035件の閲覧回数
AldoG
Unfortunately the i.MX SDK is not supported by the MCUXpresso IDE, with the only exception of the i.MX RT, the SDK works on IAR and GCC ARM only.
Aldo.
