GUI Image with buildroot for IMX8MM
1,023 次查看
kanakshilledar
I am trying to develop a GUI image for IMX8MM using buildroot.
Are there any reference defconfigs for such example? If not what are the major packages to be selected while building? I want to build on wayland.
Thanks!
864 次查看
gary_bisson
Senior Contributor III
You can use the configuration below meant for Ezurio devices:
https://github.com/boundarydevices/buildroot-external-boundary/blob/master/configs/nitrogen8mm_qt5_g...
It includes weston & qt.
8 回复数
994 次查看
Manuel_Salas
Hello @kanakshilledar
I hope you are doing very well.
Unfortunately there are not buildroot examples. At this moment we just provide support to Yocto.
Salas.
979 次查看
kanakshilledar
Hello @Manuel_Salas
I’m doing well—hope you are too!
Thank you for the clarification. Since there are no official Buildroot examples, I wanted to ask: I noticed there are some i.MX8MM-related defconfigs in the Buildroot tree. Are these community-maintained, or contributed by NXP at some point?
Best Regards
955 次查看
Manuel_Salas
Could you please share the links or examples of defconfig for buildroot?
Then, I can share information if those are community contributed.
Salas.
911 次查看
Manuel_Salas
Yes, those repos are external and are not supported by NXP. But it is interesting there are a lot of the NXP devices, maybe I can try one of them and test by my side at the end of the week.
Also, you can try to compile for your desired device and check if those are working or not.
Salas.
890 次查看
kanakshilledar
Hello @Manuel_Salas
These configs are working, but all of them are without GUI, I am looking at ones with GUI.
Thanks!
865 次查看
gary_bisson
847 次查看
kanakshilledar
Hi @gary_bisson
Thanks for sharing those. I will go through it.
