GTSMediaTestCases/ExoPlayer Test Failures
3,068件の閲覧回数
brood
We are currently developing an Android N7.1.1 tablet based on the SABRESD i.MX6Q reference design.  We are running though the Android GTS test packages and are getting a number of media codec failures (listed below).
It appears as if the codec thinks the streams are corrupt, since it fails decoding the video (looks like it runs out of space in the timestamp queue AND/OR detects a dead loop):
03-06 15:21:52.901   244  2717 I OMXPlayer: LEVEL: 1 FUNCTION: ProcessInputBuffer LINE: 628
03-06 15:21:52.901   244  2717 I OMXPlayer: init operation timeout, clip is corrupted !
03-06 15:21:52.901  2585  2716 E ACodec  : [OMX.Freescale.std.video_decoder.avc.v3.hw-based] ERROR(0x8000100b)
03-06 15:21:52.901  2585  2716 E ACodec  : signalError(omxError 0x8000100b, internalError -2147483648)
Anyone else experiencing these issues?  Any help from NXP??
Begin GTS failures:
com.google.android.media.gts.MediaPlayerTest#testM2PS_H264_AAC_480P_WV_MULTI_480P
fail
junit.framework.AssertionFailedError: Failed to validate constraints for http://redirector.gvt1.com/videoplayback?id=f2c1d5442f2b6f0f&itag=114&source=youtube&ip=0.0.0.0&ipbi...
at junit.framework.Assert.fail(Assert.java:50)
at junit.framework.Assert.assertTrue(Assert.java:20)
at com.google.android.media.gts.MediaPlayerTestBase.playWidevineVideo(MediaPlayerTestBase.java:197)
at com.google.android.media.gts.MediaPlayerTestBase.playWidevineVideoStream(MediaPlayerTestBase.java:154)
at com.google.android.media.gts.MediaPlayerTest.stream(MediaPlayerTest.java:122)
at com.google.android.media.gts.MediaPlayerTest.testM2PS_H264_AAC_480P_WV_MULTI_480P(MediaPlayerTest.java:81)
at java.lang.reflect.Method.invoke(Native Method)
at android.test.InstrumentationTestCase.runMethod(InstrumentationTestCase.java:220)
at android.test.InstrumentationTestCase.runTest(InstrumentationTestCase.java:205)
at android.test.ActivityInstrumentationTestCase2.runTest(ActivityInstrumentationTestCase2.java:192)
at junit.framework.TestCase.runBare(TestCase.java:134)
at junit.framework.TestResult$1.protect(TestResult.java:115)
at android.support.test.internal.runner.junit3.AndroidTestResult.runProtected(AndroidTestResult.java:77)
at junit.framework.TestResult.run(TestResult.java:118)
at android.support.test.internal.runner.junit3.AndroidTestResult.run(AndroidTestResult.java:55)
at junit.framework.TestCase.run(TestCase.java:124)
at android.support.test.internal.runner.junit3.NonLeakyTestSuite$NonLeakyTest.run(NonLeakyTestSuite.java:63)
at android.support.test.internal.runner.junit3.AndroidTestSuite$2.run(AndroidTestSuite.java:111)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:428)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
at java.lang.Thread.run(Thread.java:761)
com.google.android.media.gts.MediaPlayerTest#testM2PS_H264_AAC_HIGH_WV_480P
fail
junit.framework.AssertionFailedError: Failed to validate constraints for http://redirector.gvt1.com/videoplayback?id=f2c1d5442f2b6f0f&itag=62&source=youtube&ip=0.0.0.0&ipbit...
at com.google.android.media.gts.MediaPlayerTest.testM2PS_H264_AAC_HIGH_WV_480P(MediaPlayerTest.java:65)
com.google.android.media.gts.MediaPlayerTest#testM2PS_H264_AAC_HIGH_WV_480P_DOWNLOADED
fail
junit.framework.AssertionFailedError: Failed to validate constraints for http://redirector.gvt1.com/videoplayback?id=a4faa588fcc76327&itag=62&source=youtube&ip=0.0.0.0&ipbit...
at com.google.android.media.gts.MediaPlayerTestBase.playWidevineVideoDownload(MediaPlayerTestBase.java:170)
at com.google.android.media.gts.MediaPlayerTest.download(MediaPlayerTest.java:128)
at com.google.android.media.gts.MediaPlayerTest.testM2PS_H264_AAC_HIGH_WV_480P_DOWNLOADED(MediaPlayerTest.java:93)
com.google.android.media.gts.MediaPlayerTest#testM2PS_H264_AAC_MED_WV_360P
fail
junit.framework.AssertionFailedError: Failed to validate constraints for http://redirector.gvt1.com/videoplayback?id=f2c1d5442f2b6f0f&itag=61&source=youtube&ip=0.0.0.0&ipbit...
at com.google.android.media.gts.MediaPlayerTest.testM2PS_H264_AAC_MED_WV_360P(MediaPlayerTest.java:61)
com.google.android.media.gts.WidevineDashPolicyTests#testL30SLicense20SPlayback
fail
java.lang.Exception: Failed components: < Audio Reached Seconds > < Expect Exceptions > < Video Reached Seconds >
at com.google.android.media.gts.GTSTestBase.run(GTSTestBase.java:78)
at com.google.android.media.gts.WidevineDashPolicyTests.testL30SLicense20SPlayback(WidevineDashPolicyTests.java:190)
com.google.android.media.gts.WidevineDashPolicyTests#testL30SLicense40SPlayback
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL30SLicense40SPlayback(WidevineDashPolicyTests.java:200)
com.google.android.media.gts.WidevineDashPolicyTests#testL31SecondLicenseDuration
fail
java.lang.Exception: Failed components: < Expect Exceptions >
at com.google.android.media.gts.WidevineDashPolicyTests.testL31SecondLicenseDuration(WidevineDashPolicyTests.java:70)
com.google.android.media.gts.WidevineDashPolicyTests#testL31SecondPlaybackDuration
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL31SecondPlaybackDuration(WidevineDashPolicyTests.java:80)
com.google.android.media.gts.WidevineDashPolicyTests#testL320SLicense0SPlayback
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL320SLicense0SPlayback(WidevineDashPolicyTests.java:180)
com.google.android.media.gts.WidevineDashPolicyTests#testL330SecondLicenseDuration
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL330SecondLicenseDuration(WidevineDashPolicyTests.java:50)
com.google.android.media.gts.WidevineDashPolicyTests#testL360SecondLicenseDuration
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL360SecondLicenseDuration(WidevineDashPolicyTests.java:90)
com.google.android.media.gts.WidevineDashPolicyTests#testL360SecondPlaybackDuration
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL360SecondPlaybackDuration(WidevineDashPolicyTests.java:100)
com.google.android.media.gts.WidevineDashPolicyTests#testL3Heartbeat
fail
java.lang.Exception: Failed components: < Audio Reached Seconds > < Continous Video Progress > < No Exceptions > < Video Reached Seconds >
at com.google.android.media.gts.WidevineDashPolicyTests.testL3Heartbeat(WidevineDashPolicyTests.java:130)
com.google.android.media.gts.WidevineDashPolicyTests#testL3LicenseExpired
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3LicenseExpired(WidevineDashPolicyTests.java:60)
com.google.android.media.gts.WidevineDashPolicyTests#testL3LongLicenseShortPlayback
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3LongLicenseShortPlayback(WidevineDashPolicyTests.java:170)
com.google.android.media.gts.WidevineDashPolicyTests#testL3PlayHDCPNotRequired
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3PlayHDCPNotRequired(WidevineDashPolicyTests.java:298)
com.google.android.media.gts.WidevineDashPolicyTests#testL3PlayHDCPNotSpecified
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3PlayHDCPNotSpecified(WidevineDashPolicyTests.java:248)
com.google.android.media.gts.WidevineDashPolicyTests#testL3PlayHDCPV1Required
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3PlayHDCPV1Required(WidevineDashPolicyTests.java:258)
com.google.android.media.gts.WidevineDashPolicyTests#testL3PlayHDCPV2Required
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3PlayHDCPV2Required(WidevineDashPolicyTests.java:268)
com.google.android.media.gts.WidevineDashPolicyTests#testL3PlayHDCPV2_1Required
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3PlayHDCPV2_1Required(WidevineDashPolicyTests.java:278)
com.google.android.media.gts.WidevineDashPolicyTests#testL3PlayHDCPV2_2Required
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3PlayHDCPV2_2Required(WidevineDashPolicyTests.java:288)
com.google.android.media.gts.WidevineDashPolicyTests#testL3RenewalNoClientId
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3RenewalNoClientId(WidevineDashPolicyTests.java:120)
com.google.android.media.gts.WidevineDashPolicyTests#testL3RenewalNoUsage
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3RenewalNoUsage(WidevineDashPolicyTests.java:110)
com.google.android.media.gts.WidevineDashPolicyTests#testL3RenewalOutsideRecoveryWindow
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3RenewalOutsideRecoveryWindow(WidevineDashPolicyTests.java:160)
com.google.android.media.gts.WidevineDashPolicyTests#testL3RenewalWithClientId
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3RenewalWithClientId(WidevineDashPolicyTests.java:150)
com.google.android.media.gts.WidevineDashPolicyTests#testL3RenewalWithUsage
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3RenewalWithUsage(WidevineDashPolicyTests.java:140)
com.google.android.media.gts.WidevineDashPolicyTests#testL3SoftwareSecureCryptoRequired
fail
at com.google.android.media.gts.WidevineDashPolicyTests.testL3SoftwareSecureCryptoRequired(WidevineDashPolicyTests.java:214)
com.google.android.media.gts.WidevineFailureTests#testL1ContentWithL3
fail
at com.google.android.media.gts.WidevineFailureTests.testL1ContentWithL3(WidevineFailureTests.java:32)
com.google.android.media.gts.WidevineGenericOpsTests#testL3
fail
at com.google.android.media.gts.WidevineGenericOpsTests.testL3(WidevineGenericOpsTests.java:32)
com.google.android.media.gts.WidevineH264PlaybackTests#testL3With1080P30
fail
at com.google.android.media.gts.WidevineH264PlaybackTests.testL3With1080P30(WidevineH264PlaybackTests.java:86)
com.google.android.media.gts.WidevineH264PlaybackTests#testL3With240P30
fail
at com.google.android.media.gts.WidevineH264PlaybackTests.testL3With240P30(WidevineH264PlaybackTests.java:66)
com.google.android.media.gts.WidevineH264PlaybackTests#testL3With480P30
fail
at com.google.android.media.gts.WidevineH264PlaybackTests.testL3With480P30(WidevineH264PlaybackTests.java:71)
com.google.android.media.gts.WidevineH264PlaybackTests#testL3With720P30
fail
at com.google.android.media.gts.WidevineH264PlaybackTests.testL3With720P30(WidevineH264PlaybackTests.java:77)
com.google.android.media.gts.WidevineHEVCPlaybackTests#testClearWith1080P30
fail
java.lang.Exception: Failed components: < Video Reached Seconds >
at com.google.android.media.gts.WidevineHEVCPlaybackTests.testClearWith1080P30(WidevineHEVCPlaybackTests.java:138)
com.google.android.media.gts.WidevineHEVCPlaybackTests#testL3With1080P30
fail
java.lang.Exception: Failed components: < Audio Reached Seconds > < Continous Video Progress > < Video Reached Seconds >
at com.google.android.media.gts.WidevineHEVCPlaybackTests.testL3With1080P30(WidevineHEVCPlaybackTests.java:96)
com.google.android.media.gts.WidevineHEVCPlaybackTests#testL3With240P30
fail
at com.google.android.media.gts.WidevineHEVCPlaybackTests.testL3With240P30(WidevineHEVCPlaybackTests.java:71)
com.google.android.media.gts.WidevineHEVCPlaybackTests#testL3With360P30
fail
at com.google.android.media.gts.WidevineHEVCPlaybackTests.testL3With360P30(WidevineHEVCPlaybackTests.java:76)
com.google.android.media.gts.WidevineHEVCPlaybackTests#testL3With480P30
fail
at com.google.android.media.gts.WidevineHEVCPlaybackTests.testL3With480P30(WidevineHEVCPlaybackTests.java:81)
com.google.android.media.gts.WidevineHEVCPlaybackTests#testL3With720P30
fail
at com.google.android.media.gts.WidevineHEVCPlaybackTests.testL3With720P30(WidevineHEVCPlaybackTests.java:87)
com.google.android.media.gts.WidevineYouTubePerformanceTests#testL3Cenc1080P30
fail
java.lang.Exception: Failed components: < Audio Reached Seconds > < Continous Video Progress > < No Exceptions > < Performance Test > < Video Reached Seconds >
at com.google.android.media.gts.WidevineYouTubePerformanceTests.testL3Cenc1080P30(WidevineYouTubePerformanceTests.java:97)
com.google.android.media.gts.WidevineYouTubePerformanceTests#testL3Cenc240P30
fail
at com.google.android.media.gts.WidevineYouTubePerformanceTests.testL3Cenc240P30(WidevineYouTubePerformanceTests.java:77)
com.google.android.media.gts.WidevineYouTubePerformanceTests#testL3Cenc360P30
fail
at com.google.android.media.gts.WidevineYouTubePerformanceTests.testL3Cenc360P30(WidevineYouTubePerformanceTests.java:82)
com.google.android.media.gts.WidevineYouTubePerformanceTests#testL3Cenc480P30
fail
at com.google.android.media.gts.WidevineYouTubePerformanceTests.testL3Cenc480P30(WidevineYouTubePerformanceTests.java:87)
com.google.android.media.gts.WidevineYouTubePerformanceTests#testL3Cenc720P30
fail
at com.google.android.media.gts.WidevineYouTubePerformanceTests.testL3Cenc720P30(WidevineYouTubePerformanceTests.java:92)
ラベル(2)
タグ(5)
0 返答(返信)
