GStreamer video input via PCIe
2,513件の閲覧回数
romainpelletant
We are currently working on a way to transfer MPEGTS into iMX6D via PCIe to play data with GStreamer.
About PCIe, no problem for integrating it into our solution.
About Gstreamer side, we don't really know how create a video stream acceptable by GStreamer : should we create a special driver? Modify v4l2 src? Create a new plugin?
Thank you.
Romain
2,328件の閲覧回数
joanxie
if you use v4l2, you don't need to change the driver, you can use the command like:
"gst-launch v4l2src device=/dev/video0...." you can change video0 to video1 or other, which depends what device you use.
2,329件の閲覧回数
joanxie
