GStreamer dmabufheaps problem
5,018 次查看
MicMoba
Contributor V
After switching to Kernel 6.6 I am not able to get GStreamer running.
I suppose that there is problem with the dma.
imx8mp:~$ GST_DEBUG=*dma*:5 gst-launch-1.0 videotestsrc ! autovideosink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
0:00:00.072033375   889 0xffff88000b70 WARN       dmabufheapsmemory gstdmabufheaps.c:98:gst_dmabufheaps_allocator_mem_init: Could not open dmabufheaps driver
0:00:00.072123500   889 0xffff88000b70 WARN       dmabufheapsmemory gstdmabufheaps.c:119:gst_dmabufheaps_allocator_obtain: No allocator named dmabufheapsmem found
(gst-launch-1.0:889): GStreamer-CRITICAL **: 06:27:14.679: gst_buffer_pool_config_set_allocator: assertion 'allocator != NULL || params != NULL' failed
0:00:00.077851750   889 0xffff88000b70 WARN       dmabufheapsmemory gstdmabufheaps.c:119:gst_dmabufheaps_allocator_obtain: No allocator named dmabufheapsmem found
(gst-launch-1.0:889): GStreamer-CRITICAL **: 06:27:14.684: gst_buffer_pool_config_set_allocator: assertion 'allocator != NULL || params != NULL' failed
(gst-launch-1.0:889): GStreamer-CRITICAL **: 06:27:14.685: gst_object_unref: assertion 'object != NULL' failed
0:00:00.078302375   889 0xffff88000b70 DEBUG              wl_dmabuf gstwllinuxdmabuf.c:141:gst_wl_linux_dmabuf_construct_wl_buffer:<GstWlDisplay@0xaaaaec76ec60> Creating wl_buffer from DMABuf of size 307200 (320 x 240), DRM fourcc AR24
(gst-launch-1.0:889): GStreamer-Allocators-CRITICAL **: 06:27:14.685: gst_dmabuf_memory_get_fd: assertion 'gst_is_dmabuf_memory (mem)' failed
error marshalling arguments for add: dup failed: Bad file descriptor
Error marshalling request: Bad file descriptor
0:00:01.078829000   889 0xffff88000b70 ERROR              wl_dmabuf gstwllinuxdmabuf.c:217:gst_wl_linux_dmabuf_construct_wl_buffer:<allocatorsysmem0> zwp_linux_buffer_params_v1 time out
0:00:01.078882000   889 0xffff88000b70 ERROR              wl_dmabuf gstwllinuxdmabuf.c:225:gst_wl_linux_dmabuf_construct_wl_buffer:<allocatorsysmem0> can't create linux-dmabuf buffer
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
Redistribute latency...
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:02.173458875
Setting pipeline to NULL ...
 I use the wayland display server, weston (v 12.0.4) as compositor and gstreamer v1.24.0
Is there a missmatch of versions between VPU, GPU, DMA, ...? How can I check this? In the output abov is a warning "Could not open dmabufheaps driver". What driver is meant? Who provides this driver?
Actually I use the meta-imx layer for the graphics and multimedia stuff. Maybe it's a rights issue.
I miss myself a idea to investigate this problem. So I will be thankfull to get any suggestions.
4,984 次查看
MicMoba
Contributor V
I found the reason for the renaming. If the kernel config CONFIG_CMA_SIZE_MBYTES is below the
given size of linux,cma item in the devicetree the new kernel rename the device to "reserved".
In my case the kernel config was:
CONFIG_CMA_SIZE_MBYTES=320
The devicetree (imx8mp.dtsi):
resmem: reserved-memory {
   #address-cells = <2>;
   #size-cells = <2>;
   ranges;
   ocram: ocram@900000 {
      no-map;
      reg = <0 0x900000 0 0x70000>;
*    Memory reserved for optee usage. Please do not use.
*    This will be automaticky added to dtb if OP-TEE is installed.
*    optee@56000000 {
*       reg = <0 0x56000000 0 0x2000000>;
*       no-map;
   /* global autoconfigured region for contiguous allocations */
   linux,cma {
      compatible = "shared-dma-pool";
      reusable;
      size = <0 0x3C000000>;
      alloc-ranges = <0 0x40000000 0 0xC0000000>;
      linux,cma-default;
0x3C000000 is 960MiB. So it was over the 320MiB from the kernel configuration. After I changed the size to 0x14000000 the device names in /dev/dma_heap were as expect with linux,cma and linux,cma-uncached.
4 回复数
5,007 次查看
MicMoba
Contributor V
I made some investigations and found out that there were two devices renamed.
/dev/dma_heap/linux,cma is called now /dev/dma_heap/reserved
/dev/dma_heap/linux,cma-uncached is called now /dev/dma_heap/reserved-uncached
I made two symbolic links to this new devices with the old names and now the gstreamer works well.
Why are the devices renamed? And how can I change this?
4,985 次查看
MicMoba
Contributor V
   #size-cells = <2>;
   ranges;
      no-map;
*    optee@56000000 {
*       no-map;
   linux,cma {
      reusable;
      linux,cma-default;
4,974 次查看
Bio_TICFSL
ok you reduced the cma address and it works for you.
4,992 次查看
Bio_TICFSL
which BSP are you using? which target board? since you don't need to change the dma or cma memories and its not changing between bsps.
%3CLINGO-SUB%20id%3D%22lingo-sub-1961398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGStreamer%20dmabufheaps%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%86%85%E6%A0%B8%206.6%20%E5%90%8E%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%20GStreamer%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%20dma%20%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eimx8mp%3A~%24%20GST_DEBUG%3D*dma*%3A5%20gst-launch-1.0%20videotestsrc%20!%20autovideosink%0ASetting%20pipeline%20to%20PAUSED%20...%0APipeline%20is%20PREROLLING%20...%0A0%3A00%3A00.072033375%20%20%20889%200xffff88000b70%20WARN%20%20%20%20%20%20%20dmabufheapsmemory%20gstdmabufheaps.c%3A98%3Agst_dmabufheaps_allocator_mem_init%3A%20Could%20not%20open%20dmabufheaps%20driver%0A0%3A00%3A00.072123500%20%20%20889%200xffff88000b70%20WARN%20%20%20%20%20%20%20dmabufheapsmemory%20gstdmabufheaps.c%3A119%3Agst_dmabufheaps_allocator_obtain%3A%20No%20allocator%20named%20dmabufheapsmem%20found%0A%0A(gst-launch-1.0%3A889)%3A%20GStreamer-CRITICAL%20**%3A%2006%3A27%3A14.679%3A%20gst_buffer_pool_config_set_allocator%3A%20assertion%20'allocator%20!%3D%20NULL%20%7C%7C%20params%20!%3D%20NULL'%20failed%0A0%3A00%3A00.077851750%20%20%20889%200xffff88000b70%20WARN%20%20%20%20%20%20%20dmabufheapsmemory%20gstdmabufheaps.c%3A119%3Agst_dmabufheaps_allocator_obtain%3A%20No%20allocator%20named%20dmabufheapsmem%20found%0A%0A(gst-launch-1.0%3A889)%3A%20GStreamer-CRITICAL%20**%3A%2006%3A27%3A14.684%3A%20gst_buffer_pool_config_set_allocator%3A%20assertion%20'allocator%20!%3D%20NULL%20%7C%7C%20params%20!%3D%20NULL'%20failed%0A%0A(gst-launch-1.0%3A889)%3A%20GStreamer-CRITICAL%20**%3A%2006%3A27%3A14.685%3A%20gst_object_unref%3A%20assertion%20'object%20!%3D%20NULL'%20failed%0A0%3A00%3A00.078302375%20%20%20889%200xffff88000b70%20DEBUG%20%20%20%20%20%20%20%20%20%20%20%20%20%20wl_dmabuf%20gstwllinuxdmabuf.c%3A141%3Agst_wl_linux_dmabuf_construct_wl_buffer%3A%3CGSTWLDISPLAY%3E%20Creating%20wl_buffer%20from%20DMABuf%20of%20size%20307200%20(320%20x%20240)%2C%20DRM%20fourcc%20AR24%0A%0A(gst-launch-1.0%3A889)%3A%20GStreamer-Allocators-CRITICAL%20**%3A%2006%3A27%3A14.685%3A%20gst_dmabuf_memory_get_fd%3A%20assertion%20'gst_is_dmabuf_memory%20(mem)'%20failed%0Aerror%20marshalling%20arguments%20for%20add%3A%20dup%20failed%3A%20Bad%20file%20descriptor%0AError%20marshalling%20request%3A%20Bad%20file%20descriptor%0A0%3A00%3A01.078829000%20%20%20889%200xffff88000b70%20ERROR%20%20%20%20%20%20%20%20%20%20%20%20%20%20wl_dmabuf%20gstwllinuxdmabuf.c%3A217%3Agst_wl_linux_dmabuf_construct_wl_buffer%3A%3CALLOCATORSYSMEM0%3E%20zwp_linux_buffer_params_v1%20time%20out%0A0%3A00%3A01.078882000%20%20%20889%200xffff88000b70%20ERROR%20%20%20%20%20%20%20%20%20%20%20%20%20%20wl_dmabuf%20gstwllinuxdmabuf.c%3A225%3Agst_wl_linux_dmabuf_construct_wl_buffer%3A%3CALLOCATORSYSMEM0%3E%20can't%20create%20linux-dmabuf%20buffer%0APipeline%20is%20PREROLLED%20...%0ASetting%20pipeline%20to%20PLAYING%20...%0ARedistribute%20latency...%0ANew%20clock%3A%20GstSystemClock%0A%5EChandling%20interrupt.%0AInterrupt%3A%20Stopping%20pipeline%20...%0AExecution%20ended%20after%200%3A00%3A02.173458875%0ASetting%20pipeline%20to%20NULL%20...%3C%2FALLOCATORSYSMEM0%3E%3C%2FALLOCATORSYSMEM0%3E%3C%2FGSTWLDISPLAY%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20wayland%20%E6%98%BE%E7%A4%BA%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8Cweston%EF%BC%88v%2012.0.4%EF%BC%89%E4%BD%9C%E4%B8%BA%E5%90%88%E6%88%90%E5%99%A8%E5%92%8C%20gstreamer%20v1.24.0%3C%2FP%3E%3CP%3EVPU%E3%80%81GPU%E3%80%81DMA%20%E7%AD%89%E7%9A%84%E7%89%88%E6%9C%AC%E6%98%AF%E5%90%A6%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%9F%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%EF%BC%9F%E4%B8%8A%E9%9D%A2%E7%9A%84%E8%BE%93%E5%87%BA%E4%B8%AD%E6%9C%89%E4%B8%80%E6%9D%A1%E8%AD%A6%E5%91%8A%E2%80%9C%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20dmabufheaps%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E2%80%9D%E3%80%82%E6%8C%87%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%E8%B0%81%E6%8F%90%E4%BE%9B%E8%BF%99%E4%B8%AA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20meta-imx%20%E5%B1%82%E6%9D%A5%E5%A4%84%E7%90%86%E5%9B%BE%E5%BD%A2%E5%92%8C%E5%A4%9A%E5%AA%92%E4%BD%93%E5%86%85%E5%AE%B9%E3%80%82%E6%88%96%E8%AE%B8%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E6%9D%83%E5%88%A9%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%87%AA%E5%B7%B1%E4%B9%9F%E6%83%B3%E4%B8%8D%E5%88%B0%E8%B0%83%E6%9F%A5%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E6%83%B3%E6%B3%95%E3%80%82%E5%9B%A0%E6%AD%A4%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E6%BF%80%E6%94%B6%E5%88%B0%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20dmabufheaps%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E9%87%8D%E5%91%BD%E5%90%8D%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%E5%A6%82%E6%9E%9C%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%20CONFIG_CMA_SIZE_MBYTES%20%E4%BD%8E%E4%BA%8E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%E7%BB%99%E5%AE%9A%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%20linux%2Ccma%20%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%A4%A7%E5%B0%8F%EF%BC%8C%E6%96%B0%E5%86%85%E6%A0%B8%E5%B0%86%E8%AE%BE%E5%A4%87%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%E2%80%9C%E4%BF%9D%E7%95%99%E2%80%9D%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E6%98%AF%EF%BC%9A%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_CMA_SIZE_MBYTES%3D320%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%88imx8mp.dtsi%EF%BC%89%EF%BC%9A%3C%2FDIV%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eresmem%3A%20reserved-memory%20%7B%0A%20%20%20%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%23size-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20ranges%3B%0A%0A%20%20%20ocram%3A%20ocram%40900000%20%7B%0A%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x900000%200%200x70000%26gt%3B%3B%0A%20%20%20%7D%3B%0A%0A%2F*%0A*%20%20%20%20Memory%20reserved%20for%20optee%20usage.%20Please%20do%20not%20use.%0A*%20%20%20%20This%20will%20be%20automaticky%20added%20to%20dtb%20if%20OP-TEE%20is%20installed.%0A*%20%20%20%20optee%4056000000%20%7B%0A*%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x56000000%200%200x2000000%26gt%3B%3B%0A*%20%20%20%20%20%20%20no-map%3B%0A*%20%20%20%20%7D%3B%0A*%2F%0A%20%20%20%2F*%20global%20autoconfigured%20region%20for%20contiguous%20allocations%20*%2F%0A%20%20%20linux%2Ccma%20%7B%0A%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20reusable%3B%0A%20%20%20%20%20%20size%20%3D%20%26lt%3B0%200x3C000000%26gt%3B%3B%0A%20%20%20%20%20%20alloc-ranges%20%3D%20%26lt%3B0%200x40000000%200%200xC0000000%26gt%3B%3B%0A%20%20%20%20%20%20linux%2Ccma-default%3B%0A%20%20%20%7D%3B%0A...%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E0x3C000000%20%E6%98%AF%20960MiB%E3%80%82%E5%9B%A0%E6%AD%A4%E5%AE%83%E8%B6%85%E8%BF%87%E4%BA%86%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E7%9A%84%20320MiB%E3%80%82%E5%9C%A8%E6%88%91%E5%B0%86%E5%A4%A7%E5%B0%8F%E6%9B%B4%E6%94%B9%E4%B8%BA%200x14000000%20%E4%B9%8B%E5%90%8E%EF%BC%8C%2Fdev%2Fdma_heap%20%E4%B8%AD%E7%9A%84%E8%AE%BE%E5%A4%87%E5%90%8D%E7%A7%B0%E4%B8%8E%20linux%2Ccma%20%E5%92%8C%20linux%2Ccma-uncached%20%E4%B8%AD%E7%9A%84%E8%AE%BE%E5%A4%87%E5%90%8D%E7%A7%B0%E4%B8%80%E8%87%B4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1961586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20dmabufheaps%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%81%9A%E4%BA%86%E4%B8%80%E4%BA%9B%E8%B0%83%E6%9F%A5%EF%BC%8C%E5%8F%91%E7%8E%B0%E6%9C%89%E4%B8%A4%E4%B8%AA%E8%AE%BE%E5%A4%87%E8%A2%AB%E9%87%8D%E5%91%BD%E5%90%8D%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%2Fdev%2Fdma_heap%2Flinux%2Ccma%20%E7%8E%B0%E5%9C%A8%E8%A2%AB%E7%A7%B0%E4%B8%BA%20%2Fdev%2Fdma_heap%2Freserved%3C%2FP%3E%3CP%3E%2Fdev%2Fdma_heap%2Flinux%2Ccma-uncached%20%E7%8E%B0%E5%9C%A8%E8%A2%AB%E7%A7%B0%E4%B8%BA%20%2Fdev%2Fdma_heap%2Freserved-uncached%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E6%97%A7%E5%90%8D%E7%A7%B0%E4%B8%BA%E8%BF%99%E4%B8%AA%E6%96%B0%E8%AE%BE%E5%A4%87%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%A4%E4%B8%AA%E7%AC%A6%E5%8F%B7%E9%93%BE%E6%8E%A5%EF%BC%8C%E7%8E%B0%E5%9C%A8%20gstreamer%20%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BD%95%E8%AE%BE%E5%A4%87%E8%A2%AB%E9%87%8D%E6%96%B0%E5%91%BD%E5%90%8D%EF%BC%9F%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E6%94%B9%E5%8F%98%E8%BF%99%E7%A7%8D%E7%8A%B6%E5%86%B5%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
