GPU test program failed
11,985 次查看
liyigang
hi
   kernel :3.14.52
I generated rootfs with YOCTO, and errors occurred when using gpu.sh
The following are related LOG,  Please help us to analyze the possible reasons.
run gpu.sh log:
---- Running < gpu.sh > test ----
/unit_tests/GPU /unit_tests/GPU
Can not open display: (null)
vdkGetDisplay() failed.
CreateWindow() failed.
press ESC to escape...
/unit_tests/GPU
---- Test < gpu.sh > ended ----
run gpuinfo.sh log:
---- Running < gpuinfo.sh > test ----
GPU Info
gpu : 0
model : 2000
revision : 5108
gpu : 1
model : 320
revision : 5007
gpu : 2
model : 355
revision : 1215
VIDEO MEMORY:
gcvPOOL_SYSTEM:
Free : 134217728 B
Used : 0 B
Total : 134217728 B
gcvPOOL_CONTIGUOUS:
Used : 0 B
gcvPOOL_VIRTUAL:
Used : 0 B
NON PAGED MEMORY:
Used : 0 B
Paged memory Info
low: 0 bytes
high: 0 bytes
CMA memory info
cma: 0 bytes
VidMem Usage (Process 567):
Counter: vidMem (for each surface type)
All Index Vertex Texture RT Depth Bitmap TS Image Mask Scissor HZDepth
Current 0 0 0 0 0 0 0 0 0 0 0 0
Maximum 0 0 0 0 0 0 0 0 0 0 0 0
Total 0 0 0 0 0 0 0 0 0 0 0 0
Counter: vidMem (for each pool)
All 1 2 3 4 5 6 7 8 9
Counter: nonPaged
All
Current 0
Maximum 0
Total 0
Counter: contiguous
All
Current 0
Maximum 0
Total 0
Counter: mapUserMemory
All
Current 0
Maximum 0
Total 0
Counter: mapMemory
All
Current 0
Maximum 0
Total 0
VidMem Usage (Process 266):
Counter: nonPaged
All
Current 0
Maximum 0
Total 0
Counter: contiguous
All
Current 0
Maximum 0
Total 0
All
Current 0
Maximum 0
Total 0
Counter: mapMemory
All
Current 0
Maximum 0
Total 0
Idle percentage:0.000.000.000.000.000.00%
---- Test < gpuinfo.sh > ended ----
bring up log:
U-Boot 2016.03 (Apr 22 2019 - 14:06:05 +0800)
CPU: Freescale i.MX6D rev1.5 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 40C
Reset cause: POR
Board: MX6Q-Sabreauto revA
I2C: ready
DRAM: 2 GiB
force_idle_bus: sda=1 scl=0 sda.gp=0x6d scl.gp=0x3e
force_idle_bus: failed to clear bus, sda=1 scl=0
ret = 0
NAND: 0 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 3
*** Warning - bad CRC, using default environment
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc3(part 0) is current device
Net: Board Net Initialization Failed
No ethernet found.
Normal Boot
Hit ESC to stop autoboot: 0
reading boot.scr
** Unable to read file boot.scr **
reading zImage
5813096 bytes read in 163 ms (34 MiB/s)
Booting from mmc ...
reading imx6q-sabreauto.dtb
42026 bytes read in 18 ms (2.2 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x58b368 ]
bootm find images
get image 797
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800d429
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.14.52yz-v1.0 (yz@yanzhi-13) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #39 SMP PREEMPT Wed May 15 18:41:30 CST 2019
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
cma: CMA: reserved 320 MiB at 6a000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @ee72e000 s8384 r8192 d16192 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520720
Kernel command line: console=ttymxc3,115200 root=/dev/mmcblk3p2 rootwait rw
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
allocated 4194304 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 1734572K/2097152K available (7759K kernel code, 477K rwdata, 2896K rodata, 388K init, 439K bss, 362580K reserved, 270336K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0x80000000 - 0xef800000 (1784 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x80a700a4 (10657 kB)
.init : 0x80a71000 - 0x80ad20c0 ( 389 kB)
.data : 0x80ad4000 - 0x80b4b5e0 ( 478 kB)
.bss : 0x80b4b5ec - 0x80bb9238 ( 440 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32470000, Cache size: 1024 kB
cccccccccccccccccc
Switching to timer-based delay loop
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
Initializing cgroup subsys debug
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
Initializing cgroup subsys perf_event
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x1075e4d0 - 0x1075e528
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
CPU identified as i.MX6Q, silicon rev 1.5
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2625 <--> 3400 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
vddarm: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/ipu1grp-2
imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/pwm1grp
imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/usdhc2grp
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
gpio-reset mipi-dsi-reset.32: reset-gpios property missing, or not a single gpio
gpio-reset: probe of mipi-dsi-reset.32 failed with error -22
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
usb_otg_vbus: 5000 mV
usb_h1_vbus: 5000 mV
wm8960-supply: no parameters
mipi_dsi_pwr_on: no parameters
sensor-supply: 3300 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbphy_nop1.11 supply vcc not found, using dummy regulator
usbphy_nop2.12 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
imx rpmsg driver is registered.
imx_busfreq busfreq.15: DDR medium rate not supported.
Bus freq driver module loaded
futex hash table entries: 512 (order: 3, 32768 bytes)
bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 3499
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: Driver registered.
MIPI DSI driver module loaded
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_DISP0_DAT19 already requested by 20e0000.iomuxc; cannot claim for lcd.28
imx6q-pinctrl 20e0000.iomuxc: pin-111 (lcd.28) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 111 (MX6Q_PAD_DISP0_DAT19) from group ipu1grp on device 20e0000.iomuxc
mxc_lcdif lcd.28: Error applying setting, reverse things back
mxc_lcdif lcd.28: can't get/select pinctrl
mxc_lcdif: probe of lcd.28 failed with error -22
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1024x768@60: CVT Name - .786M3
mxc_sdc_fb fb.24: registered mxc display driver hdmi
Console: switching to colour frame buffer device 128x48
x 1280, y 800.
sync 0, vmode 0.
mxc_sdc_fb fb.25: registered mxc display driver ldb
mxc_hdmi 20e0000.hdmi_video: Read EDID again
imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
mxc_sdc_fb fb.26: NO mxc display driver found!
mxc_sdc_fb fb.27: NO mxc display driver found!
hannstar-cabc hannstar_cabc.17: Found interface without gpios
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.2
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 1-0008: unrecognized pfuze chip ID!
pfuze100-regulator: probe of 1-0008 failed with error -5
Serial: IMX driver
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61, base_baud = 5000000) is a IMX
mxc_hdmi 20e0000.hdmi_video: create default modelist
console [ttymxc3] enabled
21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 62, base_baud = 5000000) is a IMX
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_KEY_COL1 already requested by 21f4000.serial; cannot claim for 2008000.ecspi
imx6q-pinctrl 20e0000.iomuxc: pin-128 (2008000.ecspi) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 128 (MX6Q_PAD_KEY_COL1) from group ecspi1grp on device 20e0000.iomuxc
spi_imx 2008000.ecspi: Error applying setting, reverse things back
m25p80 spi0.0: found mr25h256, expected m25p32
m25p80 spi0.0: mr25h256 (32 Kbytes)
spi_imx 2008000.ecspi: probed
CAN device driver interface
2090000.can supply xceiver not found, using dummy regulator
flexcan 2090000.can: device registered (reg_base=f0278000, irq=142)
2094000.can supply xceiver not found, using dummy regulator
flexcan 2094000.can: device registered (reg_base=f0280000, irq=143)
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec_enet_mii_init: phy_speed 26
****************** lan8720 phy fixup *****************
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_GPIO_1 already requested by 20e0000.iomuxc; cannot claim for 2184000.usb
imx6q-pinctrl 20e0000.iomuxc: pin-137 (2184000.usb) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 137 (MX6Q_PAD_GPIO_1) from group usbotggrp on device 20e0000.iomuxc
imx_usb 2184000.usb: Error applying setting, reverse things back
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
ts-ft911 I2C Address: 0x5d
Goodix-TS 2-005d: i2c test failed attempt 1: -5
Goodix-TS 2-005d: i2c test failed attempt 2: -5
Goodix-TS 2-005d: I2C communication failure: -5
Goodix-TS: probe of 2-005d failed with error -5
usbcore: registered new interface driver usbtouchscreen
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
rtc-rx8025 2-0032: rtc core: registered rx8025 as rtc0
snvs_rtc 20cc034.snvs-rtc-lp: can't get snvs-rtc clock
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
mxc_v4l2_output v4l2_out.31: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.31: V4L2 device registered as video17
mxc_v4l2_output v4l2_out.31: V4L2 device registered as video18
mxc_v4l2_output v4l2_out.31: V4L2 device registered as video19
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
ata1: SATA link down (SStatus 0 SControl 300)
ahci-imx 2200000.sata: no device found, disabling link.
ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_SD3_DAT4 already requested by 21e8000.serial; cannot claim for 2198000.usdhc
imx6q-pinctrl 20e0000.iomuxc: pin-173 (2198000.usdhc) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 173 (MX6Q_PAD_SD3_DAT4) from group usdhc3grp on device 20e0000.iomuxc
sdhci-esdhc-imx 2198000.usdhc: Error applying setting, reverse things back
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
mmc3: no vqmmc regulator found
mmc3: no vmmc regulator found
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
Warning: No contiguous memory is reserverd for gpu.!
Warning: Will use default value(134217728) for the reserved memory!
Galcore version 5.0.11.41671
usb 1-1: new high-speed USB device number 2 using ci_hdrc
mmc3: BKOPS_EN bit is not set
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
mmc3: new high speed DDR MMC card at address 0001
mmcblk3: mmc3:0001 H8G4a 7.28 GiB
mmcblk3boot0: mmc3:0001 H8G4a partition 1 4.00 MiB
mmcblk3boot1: mmc3:0001 H8G4a partition 2 4.00 MiB
mmcblk3rpmb: mmc3:0001 H8G4a partition 3 4.00 MiB
mmcblk3: p1 p2 p3
mmcblk3boot1: unknown partition table
mmcblk3boot0: unknown partition table
usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_vpu 2040000.vpu: VPU initialized
hub 1-1.1:1.0: USB hub found
hub 1-1.1:1.0: 4 ports detected
usb 1-1.4: new high-speed USB device number 4 using ci_hdrc
caam 2100000.caam: Instantiated RNG4 SH0
hub 1-1.4:1.0: USB hub found
hub 1-1.4:1.0: 4 ports detected
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a160100 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
usb 1-1.4.3: new low-speed USB device number 5 using ci_hdrc
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] f5 95 64 71 d5 ff 4e aa
platform caam_sm: [0008] f9 c0 79 53 25 22 ba 8f
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 49 55 ee 30 a4 b4 2a 26
platform caam_sm: [0008] a8 ec c5 44 3d 01 f6 00
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 18 d4 91 f4 38 2c 04 c9
platform caam_sm: [0008] b1 56 db 69 1a 7c 9c ea
platform caam_sm: [0016] 51 07 93 ed 1e 77 15 d0
platform caam_sm: [0024] 1e 9b 26 0f 3e 4d f2 82
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 5d 55 6c cc cf 83 ec 9c
platform caam_sm: [0008] 89 da e6 c8 77 7d 0a c3
platform caam_sm: [0016] b7 51 85 53 67 72 b6 83
platform caam_sm: [0024] dc 19 a8 7f 7a d3 45 1b
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
usb 1-1.4.4: new low-speed USB device number 6 using ci_hdrc
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] c7 cc dd bc 02 46 f9 32
platform caam_sm: [0008] 54 1b 9f 83 91 49 4c 90
platform caam_sm: [0016] 9d 24 5a 55 2a 6e 4f b7
platform caam_sm: [0024] a1 6a c9 3a 72 91 a4 f7
platform caam_sm: [0032] 90 b2 94 38 9e 79 ad 0d
platform caam_sm: [0040] 97 f5 01 e0 dd 34 57 46
platform caam_sm: [0048] 0d 7c f0 d5 dc eb 53 d6
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 59 a9 29 28 85 09 fc 0f
platform caam_sm: [0008] 7f ee ca 56 39 29 2c 07
platform caam_sm: [0016] 90 1e 30 14 e0 b7 c2 5e
platform caam_sm: [0024] a7 d5 14 70 c6 11 fa cc
platform caam_sm: [0032] 21 dd 89 c5 a2 85 b6 20
platform caam_sm: [0040] 70 6f 6e 43 20 20 d0 a4
platform caam_sm: [0048] 13 4d dc 11 7c 5c 40 4f
platform caam_sm: [0056] 79 e5 5c 58 5b 7e a1 4d
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 5d e9 a9 4c dd 2c ae 8f
platform caam_sm: [0008] 49 3f 7d db c8 0f e6 47
platform caam_sm: [0016] ed b7 61 91 d5 0d fa 8e
platform caam_sm: [0024] af 31 7f 29 d0 e2 4e 5a
platform caam_sm: [0032] 14 9b 82 36 31 6b c7 77
platform caam_sm: [0040] e5 58 c1 60 9f 52 69 e6
platform caam_sm: [0048] 46 be c6 76 72 d9 99 f9
platform caam_sm: [0056] 9a be cc 25 04 9e d4 e1
platform caam_sm: [0064] 97 5c 7f d3 8f 48 e6 f1
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] ac c4 7c 80 4e 77 34 9a
platform caam_sm: [0008] 99 49 ef f6 1b d6 43 06
platform caam_sm: [0016] 90 2b 9c 00 19 e0 80 40
platform caam_sm: [0024] c2 b5 a6 5c 33 55 a0 04
platform caam_sm: [0032] 3d 8d 3d e9 70 91 ad 37
platform caam_sm: [0040] 7e ff 0d 7c 67 0a 3a d7
platform caam_sm: [0048] bd ed fd 8c 17 a1 9f a0
platform caam_sm: [0056] 00 2a 2a 5e 0c 81 91 6e
platform caam_sm: [0064] 16 44 52 1c 72 4b 55 8d
platform caam_sm: [0072] 3f 91 e0 2e 3f 73 5f 2a
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 05 28 43 41 ab f4 04 9c
platform caam_sm: [0008] 2f 13 8a d1 5b be be 92
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 4b d9 a5 e7 4a 7c 98 e6
platform caam_sm: [0024] 4a e3 fe c1 58 0b c5 d1
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
hidraw: raw HID events driver (C) Jiri Kosina
input: USB OPTICAL MOUSE as /devices/soc0/soc.0/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:0000:3825.0001/input/input0
hid-generic 0003:0000:3825.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-ci_hdrc.1-1.4.3/input0
input: SZH USB Keyboard as /devices/soc0/soc.0/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.0/0003:1C4F:0C07.0002/input/input1
hid-generic 0003:1C4F:0C07.0002: input,hidraw1: USB HID v1.10 Keyboard [SZH USB Keyboard] on usb-ci_hdrc.1-1.4.4/input0
input: SZH USB Keyboard as /devices/soc0/soc.0/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.1/0003:1C4F:0C07.0003/input/input2
hid-generic 0003:1C4F:0C07.0003: input,hidraw2: USB HID v1.10 Device [SZH USB Keyboard] on usb-ci_hdrc.1-1.4.4/input1
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
fsl-asrc 2034000.asrc: driver registered
imx-wm8960 sound.22: wm8960-hifi <-> 202c000.ssi mapping ok
imx-audio-hdmi sound-hdmi.23: failed to find SSI platform device
imx-audio-hdmi: probe of sound-hdmi.23 failed with error -22
NET: Registered protocol family 26
ipip: IPv4 over IPv4 tunneling driver
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
lib80211: common routines for IEEE802.11 drivers
Key type dns_resolver registered
sensor-supply: disabling
mipi_dsi_pwr_on: disabling
wm8960-supply: disabling
usb_otg_vbus: disabling
regulator-dummy: disabling
imx mcc test is registered.
input: gpio-keys.21 as /devices/soc0/gpio-keys.21/input/input3
rtc-rx8025 2-0032: setting system clock to 1970-01-01 10:06:55 UTC (36415)
ALSA device list:
#0: wm8960-audio
EXT3-fs (mmcblk3p2): error: couldn't mount because of unsupported optional features (240)
EXT2-fs (mmcblk3p2): error: couldn't mount because of unsupported optional features (244)
EXT4-fs (mmcblk3p2): recovery complete
EXT4-fs (mmcblk3p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 388K (80a71000 - 80ad2000)
systemd[1]: System time before build time, advancing clock.
random: systemd urandom read with 41 bits of entropy available
systemd[1]: systemd 237 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
systemd[1]: Detected architecture arm.
Welcome to NXP i.MX Release Distro 4.14-sumo (sumo)!
systemd[1]: Set hostname to <imx6qsabresd>.
systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
systemd[1]: Mounting Kernel Debug File System...
systemd[1]: Starting Load Kernel Modules...
systemd[1]: Starting Remount Root and Kernel File Systems...
systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
EXT4-fs (mmcblk3p2): re-mounted. Opts: (null)
systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
systemd[1]: Starting Journal Service...
systemd[1]: Starting udev Coldplug all Devices...
systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
systemd[1]: Mounting Temporary Directory (/tmp)...
systemd[1]: Starting Setup Virtual Console...
systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
systemd[1]: Failed to start Load Kernel Modules.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
systemd[1]: Mounted Temporary Directory (/tmp).
[ OK ] Mounted Temporary Directory (/tmp).
systemd[1]: Started Setup Virtual Console.
[ OK ] Started Setup Virtual Console.
systemd[1]: Starting Rebuild Hardware Database...
systemd[1]: Starting Create System Users...
systemd[1]: Mounting FUSE Control File System...
systemd[1]: Starting Apply Kernel Variables...
systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Create System Users.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Apply Kernel Variables.
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
[ OK ] Reached target Containers.
[ OK ] Mounted /var/volatile.
systemd-journald[180]: Received request to flush runtime journal from PID 1
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Rebuild Journal Catalog...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Load/Save Random Seed.
Starting Create Volatile Files and Directories...
[ OK ] Started Rebuild Journal Catalog.
[ OK ] Started Rebuild Dynamic Linker Cache.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Rebuild Hardware Database.
Starting udev Kernel Device Manager...
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Console System Startup Logging...
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Network Time Service (one-shot ntpdate mode)...
[ OK ] Started Xserver startup without a display manager.
[ OK ] Started Job spooling tools.
Starting System Logging Service...
Starting Telephony service...
Starting RPC Bind Service...
[ OK ] Started TEE Supplicant.
[ OK ] Started Configuration for i.MX GPU (Former rc_gpu.S).
Starting Login Service...
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Connection service...
Starting Avahi mDNS/DNS-SD Stack...
random: nonblocking pool is initialized
Starting Network Service...
Starting Start Psplash Boot Screen...
[ OK ] Started Network Service.
[ OK ] Started Console System Startup Logging.
[ OK ] Started Network Time Service (one-shot ntpdate mode).
[ OK ] Started System Logging Service.
[ OK ] Started RPC Bind Service.
[ OK ] Started Start Psplash Boot Screen.
[ OK ] Found device /dev/ttymxc0.
[ OK ] Found device /dev/ttymxc3.
FAT-fs (mmcblk3p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
EXT4-fs (mmcblk3p3): recovery complete
EXT4-fs (mmcblk3p3): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Started Login Service.
[ OK ] Started Telephony service.
fec 2188000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Connection service.
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Starting Hostname Service...
Starting WPA supplicant...
Starting Save/Restore Sound Card State...
[ OK ] Started Updates psplash to basic.
Starting Kernel Logging Service...
[ OK ] Started WPA supplicant.
[ OK ] Reached target Network.
[ OK ] Started Update psplash to network.
Starting Terminate Psplash Boot Screen...
Starting /etc/rc.local Compatibility...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Terminate Psplash Boot Screen.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Hostname Service.
[ OK ] Started Serial Getty on ttymxc3.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Sound Card.
[ OK ] Started Kernel Logging Service.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
NXP i.MX Release Distro 4.14-sumo imx6qsabresd ttymxc3
imx6qsabresd login:
imx6qsabresd login:
imx6qsabresd login:
imx6qsabresd login:
imx6qsabresd login:
imx6qsabresd login:
imx6qsabresd login: root
root@imx6qsabresd:~# ls /dev/galcore
/dev/galcore
root@imx6qsabresd:~# ls -l /dev/galcore
crw-rw---- 1 root video 199, 0 May 16 01:32 /dev/galcore
11,433 次查看
liyigang
I see the following information output from the galcore driver
   drv_ioctl(612): input or/and output structures are invalid.
   gcmkONERROR: status=-1(gcvSTATUS_INVALID_ARGUMENT) @ drv_ioctl(615)
In both versions of the driver, the definition of struct_gcsHAL_INTERFACE structure is not exactly the same. I think this may be the cause of this problem.
If I still want to use the imx-4.14.98 filesystem, what changes are needed to adapt the 3.14.52 kernel?
9 回复数
11,434 次查看
liyigang
11,433 次查看
shivanipatel
Senior Contributor II
Hi, li yigang‌
You need to set below configurations before running the GPU test script:
  1. Enable Kernel Configuration using menuconfig- CONFIG_MXC_GPU_VIV=y.
  2. Once device boot, set Display Environment Variable in board console with this "export DISPLAY=:0" command.
Shivani
11,432 次查看
liyigang
I'm sure that CONFIG_MXC_GPU_VIV=y has been set, and the same KERNEL with imx-4.1.15-1.0.0 rootfs is normal, but imx-4.14.98 is not.
When strace. / g2d_test is run on 4.14 ROOTFS, the following error occurs in the IOCTL call:
       openat(AT_FDCWD, "/dev/galcore", O_RDWR) = 3
       ioctl(3, _IOC(0, 0x75, 0x30, 0), 0x7ebf55e0) = -1 ENOTTY (Inappropriate ioctl for device)
11,433 次查看
liyigang
Maybe the imx-4.14.98 file system is not compatible with the old BSP in GPU. Today, after I changed it to imx-4.1.15-1.0.0, the GPU test program is normal.
11,432 次查看
liyigang
Some software in imx-4.1.15-1.0.0 is too old
11,432 次查看
liyigang
Running g2d_test at the terminal has the following abnormal information:
g2d_open: fail with status -7
g2d_open fail
11,432 次查看
Bio_TICFSL
You have to open a new file for it.
regards
11,433 次查看
liyigang
I don't understand what you mean.Can you explain in detail how to operate it?
11,432 次查看
liyigang
Running gpu.sh at the terminal has the following abnormal information:“failed to open device:no such file or directory, Try again”
Running glmark2-es2 has the same exception information
