Hello All,
The FreeRTOS examples of CM4 (evkmimxrt1160_freertos_hello_cm4) provided with the SDK does not work on i.MX RT1160 Evaluation Kit.
Could you solve this issue?
Mc2023
解決済! 解決策の投稿を見る。
Hi Miguel,
Thanks for your message!
Did you use the GUI Flash tool or the debug mode?
In my case, it works in debug mode but I cannot use the GUI Flash tool.
Hi Miguel,
Hi @Mc2023
The example works for me, please make sure all the jumpers are connected correctly. Check this Getting Started to see jumpers J5, J6, J7 and J8. In case this doesn't work, read this post to regain access to the debugger.
Best Regards, Miguel.
