FlexSPI IP Command Read Transfer Size Limit
681件の閲覧回数
kvsh
I am reading 256 bytes using a FlexSPI IP command DMA read on an RT1050 custom board. The first 128 bytes are correct, but the second 128 bytes repeat the first 128 bytes. Is it correct that it is not possible to read more than the RX FIFO size in one IP command read transfer, and that I need to use an AHB read instead?
Code is below.
AT_NONCACHEABLE_SECTION_ALIGN(uint32_t destAddr[256], 8);
edma_handle_t txEdmaHandle, rxEdmaHandle;
flexspi_edma_handle_t flexspiEdmaHandle;
#define FLEXSPI_DMA_TX_CHANNEL 1
#define FLEXSPI_DMA_RX_CHANNEL 0
#define NUM_BYTES_RX 256
edma_config_t userConfig;
DMAMUX_Init(EXAMPLE_DMAMUX);
DMAMUX_EnableAlwaysOn(EXAMPLE_DMAMUX, 0, true);
DMAMUX_EnableChannel(EXAMPLE_DMAMUX, 0);
EDMA_GetDefaultConfig(&userConfig);
EDMA_Init(EXAMPLE_DMA, &userConfig);
EDMA_CreateHandle(&rxEdmaHandle, EXAMPLE_DMA, FLEXSPI_DMA_RX_CHANNEL);
EDMA_CreateHandle(&txEdmaHandle, EXAMPLE_DMA, FLEXSPI_DMA_TX_CHANNEL);
FLEXSPI_TransferCreateHandleEDMA(EXAMPLE_FLEXSPI,
&flexspiEdmaHandle,
EDMA_Callback,
NULL,
&txEdmaHandle,
&rxEdmaHandle);
// tried different sizes, no success
flexspiEdmaHandle.nsize = kFLEXPSI_EDMAnSize8Bytes; //kFLEXPSI_EDMAnSize1Bytes;
flexspi_transfer_t xfer = {
.port = FLASH_PORT,
.cmdType = kFLEXSPI_Read,
.seqIndex = 0,
.SeqNumber = 1,
.deviceAddress= 0,
.data = destAddr,
.dataSize = NUM_BYTES_RX
status_t st = FLEXSPI_TransferEDMA(EXAMPLE_FLEXSPI, &flexspiEdmaHandle, &xfer);
640件の閲覧回数
Gavin_Jia
Hi @kvsh ,
Thanks for your interest in NXP MIMXRT series!
128 bytes is only the capacity of the IP RX FIFO; it is not the total transfer limit for the IP command read. Please refer to `evkmimxrt1170_flexspi_nor_edma_transfer_cm7` in the RT1170-EVK SDK. Thanks!
Gavin
%3CLINGO-SUB%20id%3D%22lingo-sub-2339359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlexSPI%20IP%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%BB%A2%E9%80%81%E3%82%B5%E3%82%A4%E3%82%BA%E5%88%B6%E9%99%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3ERT1050%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E3%80%81FlexSPI%20IP%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89DMA%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6256%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE128%E3%83%90%E3%82%A4%E3%83%88%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE128%E3%83%90%E3%82%A4%E3%83%88%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AE128%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%821%E5%9B%9E%E3%81%AEIP%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%BB%A2%E9%80%81%E3%81%A7RX%20FIFO%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABAHB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%80%81%E3%81%A8%E3%81%84%E3%81%86%E7%90%86%E8%A7%A3%E3%81%A7%E5%90%88%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3EdestAddr%5B256%5D%2C%208)%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Eedma_handle_t%3C%2FSPAN%3E%20%3CSPAN%3EtxEdmaHandle%E3%80%81rxEdmaHandle%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eflexspi_edma_handle_t%3C%2FSPAN%3E%20%3CSPAN%3EflexspiEdmaHandle%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3EFLEXSPI_DMA_TX_CHANNEL%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3EFLEXSPI_DMA_RX_CHANNEL%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23define%20NUM_BYTES_RX%20256%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Eedma_config_t%3C%2FSPAN%3E%20%3CSPAN%3EuserConfig%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EDMAMUX_Init(EXAMPLE_DMAMUX)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EDMAMUX_EnableAlwaysOn(EXAMPLE_DMAMUX%2C%200%2C%20true)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EDMAMUX_EnableChannel(EXAMPLE_DMAMUX%2C%200)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EEDMA_GetDefaultConfig(%26amp%3BuserConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EEDMA_Init(EXAMPLE_DMA%2C%20%26amp%3BuserConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EEDMA_CreateHandle(%26amp%3BrxEdmaHandle%2C%20EXAMPLE_DMA%2C%20FLEXSPI_DMA_RX_CHANNEL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EEDMA_CreateHandle(%26amp%3BtxEdmaHandle%2C%20EXAMPLE_DMA%2C%20FLEXSPI_DMA_TX_CHANNEL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EFLEXSPI_TransferCreateHandleEDMA(EXAMPLE_FLEXSPI%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26amp%3BflexspiEdmaHandle%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EEDMA_%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENULL%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26amp%3BtxEdmaHandle%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26amp%3BrxEdmaHandle)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%20%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8B%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%3C%2FP%3E%3CP%3E%3CSPAN%3EflexspiEdmaHandle.nsize%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkFLEXPSI_EDMAnSize8Bytes%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2FkFLEXPSI_EDMAnSize1Bytes%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Eflexspi_transfer_t%3C%2FSPAN%3E%20%3CSPAN%3Exfer%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.port%20%3D%20FLASH_PORT%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.cmdType%20%3D%3C%2FSPAN%3E%20%3CSPAN%3EkFLEXSPI_Read%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.seqIndex%20%3D%200%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.SeqNumber%20%3D%201%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.deviceAddress%3D%200%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.data%20%3D%20destAddr%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.dataSize%20%3D%20NUM_BYTES_RX%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Estatus_t%3C%2FSPAN%3E%20%3CSPAN%3Est%20%3D%20FLEXSPI_TransferEDMA(EXAMPLE_FLEXSPI%2C%20%26amp%3BflexspiEdmaHandle%2C%20%26amp%3Bxfer)%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FlexSPI%20IP%20Command%20Read%20Transfer%20Size%20Limit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261016%22%20target%3D%22_blank%22%3E%40kvsh%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3ENXP%20MIMXRT%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AB%E3%81%94%E9%96%A2%E5%BF%83%E3%82%92%E3%81%8A%E5%AF%84%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3E128%E3%83%90%E3%82%A4%E3%83%88%E3%81%AFIP%20RX%20FIFO%E3%81%AE%E5%AE%B9%E9%87%8F%E3%81%AB%E9%81%8E%E3%81%8E%E3%81%9A%E3%80%81IP%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AE%E5%90%88%E8%A8%88%E8%BB%A2%E9%80%81%E5%88%B6%E9%99%90%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82RT1170-EVK%20SDK%20%E3%81%AE%20%60evkmimxrt1170_flexspi_nor_edma_transfer_cm7%60%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%AE%E3%83%A3%E3%83%93%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
