I am working with i.MX8MM EVK, Yocto distribution imx-sumo-4.14
All these days I am using Linux PC and using "dd" command to flash the SDCARD.
I wish to flash the build binaries .wic.bz2 images into SDCARD using windows PC.
Also i wish to flash only the kernel image using windows PC.
with USB and UART interface.
Could you please suggest the technique and steps to flash the SDCARD.
Thank you, Sreedhar
