Flash memory for iMX233
2,331件の閲覧回数
MarcellusPereir
Dear ALL,
I'm facing a problem, while designing my own iMX233 board. I started using the same memories of the kit, while using the QFP version of the processor. So, the flash memory is the Samsung K9LBG08U0D. But now, that part is obsolete and I can't find another one to replace it.
Do you have any ideas, guys? Did someone faced similar problem?
Thank you very much,
Marcellus Pereira
3 返答(返信)
2,148件の閲覧回数
MarcellusPereir
I found it now...
Thank you both, guys!
Manuel Martinez said:
I used this flash:
http://es.rs-online.com/web/p/products/668-6183/
And this RAM:
http://es.rs-online.com/web/p/products/668-6192/
As Balaji said any from Micron or Hynix of similar characteristics should work fine.
Regards.
Manu.
2,148件の閲覧回数
manwenwe
Fresh Out Contributor
I used this flash:
And this RAM:
Regards.
Manu.
2,148件の閲覧回数
Balaji_ng
Use similar parts from Micron or Hynix, which are not obsolete. They work fine.
Balaji.V
