Fixed read-only value
2,178件の閲覧回数
liyuan
Hello,I'm now using i.mx6q chip todo some development.but I have some troubles when I modifying my u-boot.Could you give me some information about "Fixed read-only value  reflecting the MAJOR field of the RTL version".I need to kown the fixed read-only value.Thankyou!
ラベル(2)
2,125件の閲覧回数
Hi li
usually attached document Chapter 1 Porting U-Boot
should be sufficient for successfull Uboot development.
Where did you find "Fixed read-only value  reflecting the MAJOR field of the RTL version"
and why it is important for you ?
