Finding u-boot code in SD card using a hex viewer
2,720件の閲覧回数
maniam
I am using NITROGEN6X board from Boundary Devices (here)
The linux kernel uses U-boot as the boot loader.
I open the SD Card content in a hex viewer and I can see/decode the MBR in sector 0.
I am now trying to find the stage 1 (secondary program loader) and stage 2 code in the hex viewer.
Is there any documents describing this?
- Mani
3 返答(返信)
2,524件の閲覧回数
gary_bisson
Senior Contributor III
Hi Mani,
All our platforms come with U-Boot flashed in NOR flash, you won't be able to see U-Boot in our SDCard images since it is not there. That is how we can provide one single sdcard image that works on all our platforms.
You can learn how to build/flash U-Boot on our platforms here:
https://boundarydevices.com/u-boot-v2016-03/
Gary
2,524件の閲覧回数
maniam
Thanks! Is there any way to dump the NOR flash to a file?
2,524件の閲覧回数
gary_bisson
Yes, U-Boot is located in /dev/mtd0, you can cat its content to a file directly.
Gary
