File linux command on BSP
2,550件の閲覧回数
fabio_poiatti
I compiled a BSP from yocto poky distro 2.6.1
But I haven't the "file" command
Which kind of library I have to install by command IMAGE_INSTALL_append in conf/local.conf?
Or is there any other way to have the "file" command working on BSP?
Fabio
4 返答(返信)
2,469件の閲覧回数
jimmychan
2,469件の閲覧回数
fabio_poiatti
I was hoping file command included in some library already done
thanks
2,469件の閲覧回数
jimmychan
We don't have library for this 'file' command. You may build it by yourself or put it in Yocto BSP to build it.
2,469件の閲覧回数
fabio_poiatti
thanks
