Failed to run weston client applications(one on each display) on LVDS displays
856 次查看
saikrishna
I have enabled wayland and weston in the yocto source (NXP BSP (5.4.47)) and using imx8QM-MEK board. Connected two Monitors on LVDS0-CH0 and LVDS1-CH0 using imx-lvds-hdmi converters respectively. And would like to run two different weston client applications (weston-flower on LVDS0-CH0, weston-simple-egl on LVDS1-CH0). But I can able to run any weston client application on LVDS0-CH0 only.
I would appreciate any suggestions on how to do this.
Attaching my_changes_imx8QM.zip (contains weston.ini, weston.log and device-tree-changes.txt)
826 次查看
saikrishna
Any updates on this?
