Failed building libxcb
3,374 次查看
caohaifeng
Hello,All,
I am trying to build gnome environment by using FSL gnome release package.Some error have been solved according to the topic
"FSL gnome release package" build fails at python build stage
The error information is :
checking for xsltproc... no
configure: error: XCB requires xsltproc.
error: Bad exit status from /home/chf/ltib/tmp/rpm-tmp.7735 (%build)
RPM build errors:
Build time for libxcb: 20 seconds
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Mon Jun  3 21:50:10 2013
Ended:   Mon Jun  3 22:26:39 2013
Elapsed: 2189 seconds
These packages failed to build:
libxcb
Build Failed
How to solve it?
Haifeng
标签 (2)
标记 (4)
2,078 次查看
caohaifeng
Sorry, the solution is
sudo apt-get install xsltproc
2,079 次查看
caohaifeng
