FUSE programming in imx7 ULP
3,387件の閲覧回数
ko-hey
Senior Contributor II
Hi all,
I'd like to know the way to program eFUSE in i.MX7ULP.
I've checked a following but can't understand how to do it.
https://www.nxp.com/docs/en/application-note/AN4581.pdf
I guess there are several way to program eFUSE in i.MX7ULP such as using uuu, u-boot.
Could someone share sufficient documentation or example script ?
Ko-hey
タグ(4)
3,255件の閲覧回数
kunalkotecha1
Hi ko-hey,
Please refer to How to Program Fuses documents that give examples on various ways to program fuses. You can use that as a sample for i.MX7ULP as well. Also, attached the Fusemap sheet that can help make things clear about OTP Fuses.
Kunal
3,256件の閲覧回数
kunalkotecha1
Hi ko-hey,
Kunal
