FRDM-MX95 AAOS 16
FRDM-MX95 AAOS 16
FlynHawaiian
Will Android AAOS 16 image from nxp install on the FRDM-MX95?
Secondarily, can an m.2 hard drive be installed in the slot?
FlynHawaiian
1) Is it possible I can build an android 16 image, as you say the source code for the frdm is there.
2) Is there a particular reason that AAOS 16 couldn't be run on the FRDM-MX95?  Since the processor is a MIMX9596XVTXNAC, it has full features and the only difference is the memory speed.  The MX95EVK uses the MIMX9596AVZXNAC.
Since both processors are full function processors I can't imagine there being a reason that AAOS nor Android shouldn't be able to be installed on the FRDM-mx95 board.  Could you shed some light on the reasoning?
saajid
Hello Flyn,
I am also looking for an Android image or source package compatible with the FRDM-i.MX95. Have you found anything suitable?
Rita_Wang
NXP documentation supports Android 16 and AAOS on i.MX 95 EVK/Verdin boards—not FRDM-IMX95, for the Android 16 BSP have the source code for the FRDM-95, but we have not rest it by now. And the FRDM-IMX95 does include an M.2 Key-M slot intended for AI cards and SSDs.
%3CLINGO-SUB%20id%3D%22lingo-sub-2372071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MX95%20AAOS%2016%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWill%20Android%20AAOS%2016%20image%20from%20nxp%20install%20on%20the%20FRDM-MX95%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESecondarily%2C%20can%20an%20m.2%20hard%20drive%20be%20installed%20in%20the%20slot%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2373254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MX95%20AAOS%2016%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2373254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1)%20Is%20it%20possible%20I%20can%20build%20an%20android%2016%20image%2C%20as%20you%20say%20the%20source%20code%20for%20the%20frdm%20is%20there.%20%26nbsp%3B%3C%2FP%3E%3CP%3E2)%20Is%20there%20a%20particular%20reason%20that%20AAOS%2016%20couldn't%20be%20run%20on%20the%20FRDM-MX95%3F%20%26nbsp%3BSince%20the%20processor%20is%20a%26nbsp%3BMIMX9596XVTXNAC%2C%20it%20has%20full%20features%20and%20the%20only%20difference%20is%20the%20memory%20speed.%20%26nbsp%3BThe%20MX95EVK%20uses%20the%26nbsp%3BMIMX9596AVZXNAC.%20%26nbsp%3B%3C%2FP%3E%3CP%3ESince%20both%20processors%20are%20full%20function%20processors%20I%20can't%20imagine%20there%20being%20a%20reason%20that%20AAOS%20nor%20Android%20shouldn't%20be%20able%20to%20be%20installed%20on%20the%20FRDM-mx95%20board.%20%26nbsp%3BCould%20you%20shed%20some%20light%20on%20the%20reasoning%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MX95%20AAOS%2016%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ENXP%20documentation%20supports%20Android%2016%20and%20AAOS%20on%20i.MX%2095%20EVK%2FVerdin%20boards%E2%80%94not%20FRDM-IMX95%EF%BC%8C%20for%20the%20Android%2016%20BSP%20have%20the%20source%20code%20for%20the%20FRDM-95%2C%20but%20we%20have%20not%20rest%20it%20by%20now.%20A%3C%2FSPAN%3E%3CSPAN%3End%20the%20FRDM-IMX95%20does%20include%20an%20M.2%20Key-M%20slot%20intended%20for%20AI%20cards%20and%20SSDs.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MX95%20AAOS%2016%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello%20Flyn%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20am%20also%20looking%20for%20an%20Android%20image%20or%20source%20package%20compatible%20with%20the%20FRDM-i.MX95.%20Have%20you%20found%20anything%20suitable%3F%3C%2FLINGO-BODY%3E
