FRDM-IMX93 not recognizing RPI-CAM-MIPI
jventura
Hi, i´m trying to make RPI-CAM-MIPI work with the FRDM-IMX93 board.
I followed the user manual for the board:
https://docs.nxp.com/bundle/UM12181/page/topics/camera_module_rpi_cam_mipi.html
I connected the camera as instructed.
I got the ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin from ONSEMI github (https://github.com/ONSemiconductor/ap1302_binaries/tree/main/NXP_i.MX93), renamed it and put it in the board:
root@imx93-11x11-lpddr4x-frdm:~# ls /lib/firmware/imx/camera/
ap1302.fw
I rebooted the camera, but the log wasn´t the same as in the manual:
root@imx93-11x11-lpddr4x-frdm:~# dmesg | grep ap1302
[ 0.341004] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.371040] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.411142] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.433309] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.464010] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.476107] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.495817] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.093316] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.104580] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
and the camera doesn´t seem to appear:
root@imx93-11x11-lpddr4x-frdm:~# media-ctl -p
Failed to enumerate /dev/media0 (-2)
root@imx93-11x11-lpddr4x-frdm:~# v4l2-ctl --list-devices
mxc-isi-cap (platform:4ae40000.isi):
/dev/video0
/dev/video1
root@imx93-11x11-lpddr4x-frdm:~# i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- UU -- -- UU -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I've rechecked everything. I'm stuck. Any ideas what i should try?
Zhiming_Liu
Hi @jventura
ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin is correct one.  Please try below suggestion from reference manual
A firmware named ap1302_ar0144_single_fw.bin is needed. Put it under the /lib/firmware folder.
Zhiming
jventura
I´ve attached the photos, but i also checked continuity with a multimeter and it´s ok, the pins on the FRDM are reaching the CAM ones...
jventura
Here it is
jventura
From the other side 
Zhiming_Liu
Hi @jventura
Your connection is wrong, the blue side should be the same as the camera side.
Zhiming
jventura
thanks @Zhiming_Liu
I checked it so many times, and every time i missed.
Anyways, it got better but it seems I still have a problem with the .fw:
[ 0.340881] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.370918] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.411017] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.433185] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.463890] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.475987] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.495704] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.098808] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.110107] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 10.757527] ap1302 2-003c: Direct firmware load for ap1302_ar0144_single_fw.bin failed with error -2
[ 10.757549] ap1302 2-003c: Falling back to sysfs fallback for: ap1302_ar0144_single_fw.bin
[ 10.770396] ap1302 2-003c: Failed to request firmware: -2
[ 10.818467] ap1302 2-003c: probe with driver ap1302 failed with error -2
ap1302.fw
Is the ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin from ONSEMI github (https://github.com/ONSemiconductor/ap1302_binaries/tree/main/NXP_i.MX93) the correct one?
Zhiming_Liu
Hi @jventura
Zhiming
jventura
thanks Zhiming, it worked!
The Gopoint DMS demo doesn´t see it though... I think it may be something with the media pipeline, I´ll look into that.
Zhiming_Liu
Hi @jventura
Can you share the photo to show the connection between RPI-CAM-MIPI and FRDM93?
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2379079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20i%C2%B4m%20trying%20to%20make%26nbsp%3BRPI-CAM-MIPI%20work%20with%20the%20FRDM-IMX93%20board.%3C%2FP%3E%3CP%3EI%20followed%20the%20user%20manual%20for%20the%20board%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM12181%2Fpage%2Ftopics%2Fcamera_module_rpi_cam_mipi.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM12181%2Fpage%2Ftopics%2Fcamera_module_rpi_cam_mipi.html%3C%2FA%3E%3C%2FP%3E%3CP%3EI%20connected%20the%20camera%20as%20instructed.%3C%2FP%3E%3CP%3EI%20got%20the%26nbsp%3Bap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%20from%20ONSEMI%20github%20(%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%3C%2FA%3E)%2C%20renamed%20it%20and%20put%20it%20in%20the%20board%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20ls%20%2Flib%2Ffirmware%2Fimx%2Fcamera%2F%3CBR%20%2F%3Eap1302.fw%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EI%20rebooted%20the%20camera%2C%20but%20the%20log%20wasn%C2%B4t%20the%20same%20as%20in%20the%20manual%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20dmesg%20%7C%20grep%20ap1302%3CBR%20%2F%3E%5B%200.341004%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.371040%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%200.411142%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.433309%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.464010%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%200.476107%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.495817%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%202.093316%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%202.104580%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3Eand%20the%20camera%20doesn%C2%B4t%20seem%20to%20appear%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20media-ctl%20-p%3CBR%20%2F%3EFailed%20to%20enumerate%20%2Fdev%2Fmedia0%20(-2)%3CBR%20%2F%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20v4l2-ctl%20--list-devices%3CBR%20%2F%3Emxc-isi-cap%20(platform%3A4ae40000.isi)%3A%3CBR%20%2F%3E%2Fdev%2Fvideo0%3CBR%20%2F%3E%2Fdev%2Fvideo1%3C%2FP%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20i2cdetect%20-y%201%3CBR%20%2F%3E0%201%202%203%204%205%206%207%208%209%20a%20b%20c%20d%20e%20f%3CBR%20%2F%3E00%3A%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E10%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E20%3A%20--%20--%20UU%20--%20--%20UU%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E30%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E40%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E50%3A%2050%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E60%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E70%3A%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Aroot%40imx93-11x11-lpddr4x-frdm%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EI've%20rechecked%20everything.%20I'm%20stuck.%20Any%20ideas%20what%20i%20should%20try%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3EYour%20connection%20is%20wrong%2C%20the%20blue%20side%20should%20be%20the%20same%20as%20the%20camera%20side.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388629i75417AA223BC31DB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1781136494125.png%22%20alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%C2%B4ve%20attached%20the%20photos%2C%20but%20i%20also%20checked%20continuity%20with%20a%20multimeter%20and%20it%C2%B4s%20ok%2C%20the%20pins%20on%20the%20FRDM%20are%20reaching%20the%20CAM%20ones...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388595i78F0E83F0556BC55%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RPICAMConectionBack.png%22%20alt%3D%22RPICAMConectionBack.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EFrom%20the%20other%20side%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388594iBD7AA6D9459743E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RPICAMConection.png%22%20alt%3D%22RPICAMConection.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EHere%20it%20is%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3ECan%20you%20share%20the%20photo%20to%20show%20the%26nbsp%3Bconnection%20between%26nbsp%3BRPI-CAM-MIPI%20and%20FRDM93%3F%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethanks%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%26nbsp%3B%3CLI-EMOJI%20id%3D%22lia_grinning-face-with-smiling-eyes%22%20title%3D%22%3Agrinning_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%3CBR%20%2F%3EI%20checked%20it%20so%20many%20times%2C%20and%20every%20time%20i%20missed.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAnyways%2C%20it%20got%20better%20but%20it%20seems%20I%20still%20have%20a%20problem%20with%20the%20.fw%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20dmesg%20%7C%20grep%20ap1302%3CBR%20%2F%3E%5B%200.340881%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.370918%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%200.411017%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.433185%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.463890%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%200.475987%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%200.495704%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%202.098808%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%202.110107%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%5B%2010.757527%5D%20ap1302%202-003c%3A%20Direct%20firmware%20load%20for%20ap1302_ar0144_single_fw.bin%20failed%20with%20error%20-2%3CBR%20%2F%3E%5B%2010.757549%5D%20ap1302%202-003c%3A%20Falling%20back%20to%20sysfs%20fallback%20for%3A%20ap1302_ar0144_single_fw.bin%3CBR%20%2F%3E%5B%2010.770396%5D%20ap1302%202-003c%3A%20Failed%20to%20request%20firmware%3A%20-2%3CBR%20%2F%3E%5B%2010.818467%5D%20ap1302%202-003c%3A%20probe%20with%20driver%20ap1302%20failed%20with%20error%20-2%3CBR%20%2F%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20media-ctl%20-p%3CBR%20%2F%3EFailed%20to%20enumerate%20%2Fdev%2Fmedia0%20(-2)%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Aroot%40imx93-11x11-lpddr4x-frdm%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%3C%2FA%3E%3CBR%20%2F%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20ls%20%2Flib%2Ffirmware%2Fimx%2Fcamera%2F%3CBR%20%2F%3Eap1302.fw%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EIs%26nbsp%3B%3CSPAN%3Ethe%26nbsp%3Bap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%20from%20ONSEMI%20github%20(%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%3C%2FA%3E%3CSPAN%3E)%20the%20correct%20one%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3Eap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%20is%20correct%20one.%26nbsp%3B%20Please%20try%20below%20suggestion%20from%20%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FRM00293%2Fpage%2Ftopics%2Far0144.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ereference%20manual%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EA%20firmware%20named%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22ph%20codeph%22%3Eap1302_ar0144_single_fw.bin%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3Bis%20needed.%20Put%20it%20under%20the%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22ph%20codeph%22%3E%2Flib%2Ffirmware%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3Bfolder.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2381436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2381436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ethanks%20Zhiming%2C%20it%20worked!%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20Gopoint%20DMS%20demo%20doesn%C2%B4t%20see%20it%20though...%20I%20think%20it%20may%20be%20something%20with%20the%20media%20pipeline%2C%20I%C2%B4ll%20look%20into%20that.%3C%2FLINGO-BODY%3E
