FRDM-IMX93 not recognizing RPI-CAM-MIPI
1,523 次查看
jventura
Hi, i´m trying to make RPI-CAM-MIPI work with the FRDM-IMX93 board.
I followed the user manual for the board:
https://docs.nxp.com/bundle/UM12181/page/topics/camera_module_rpi_cam_mipi.html
I connected the camera as instructed.
I got the ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin from ONSEMI github (https://github.com/ONSemiconductor/ap1302_binaries/tree/main/NXP_i.MX93), renamed it and put it in the board:
root@imx93-11x11-lpddr4x-frdm:~# ls /lib/firmware/imx/camera/
ap1302.fw
I rebooted the camera, but the log wasn´t the same as in the manual:
root@imx93-11x11-lpddr4x-frdm:~# dmesg | grep ap1302
[ 0.341004] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.371040] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.411142] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.433309] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.464010] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.476107] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.495817] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.093316] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.104580] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
and the camera doesn´t seem to appear:
root@imx93-11x11-lpddr4x-frdm:~# media-ctl -p
Failed to enumerate /dev/media0 (-2)
root@imx93-11x11-lpddr4x-frdm:~# v4l2-ctl --list-devices
mxc-isi-cap (platform:4ae40000.isi):
/dev/video0
/dev/video1
root@imx93-11x11-lpddr4x-frdm:~# i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- UU -- -- UU -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I've rechecked everything. I'm stuck. Any ideas what i should try?
1,395 次查看
Zhiming_Liu
Hi @jventura
ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin is correct one.  Please try below suggestion from reference manual
A firmware named ap1302_ar0144_single_fw.bin is needed. Put it under the /lib/firmware folder.
Zhiming
8 回复数
1,463 次查看
jventura
I´ve attached the photos, but i also checked continuity with a multimeter and it´s ok, the pins on the FRDM are reaching the CAM ones...
1,467 次查看
jventura
Here it is
1,467 次查看
jventura
From the other side 
1,454 次查看
Zhiming_Liu
Hi @jventura
Your connection is wrong, the blue side should be the same as the camera side.
Zhiming
1,445 次查看
jventura
thanks @Zhiming_Liu
I checked it so many times, and every time i missed.
Anyways, it got better but it seems I still have a problem with the .fw:
[ 0.340881] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.370918] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.411017] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.433185] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.463890] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.475987] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.495704] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.098808] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.110107] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 10.757527] ap1302 2-003c: Direct firmware load for ap1302_ar0144_single_fw.bin failed with error -2
[ 10.757549] ap1302 2-003c: Falling back to sysfs fallback for: ap1302_ar0144_single_fw.bin
[ 10.770396] ap1302 2-003c: Failed to request firmware: -2
[ 10.818467] ap1302 2-003c: probe with driver ap1302 failed with error -2
ap1302.fw
Is the ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin from ONSEMI github (https://github.com/ONSemiconductor/ap1302_binaries/tree/main/NXP_i.MX93) the correct one?
1,396 次查看
Zhiming_Liu
Hi @jventura
Zhiming
1,205 次查看
jventura
thanks Zhiming, it worked!
The Gopoint DMS demo doesn´t see it though... I think it may be something with the media pipeline, I´ll look into that.
1,489 次查看
Zhiming_Liu
Hi @jventura
Can you share the photo to show the connection between RPI-CAM-MIPI and FRDM93?
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2379079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-IMX93%20%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%83%B3%E8%AE%A9%20RPI-CAM-MIPI%20%E4%B8%8E%20FRDM-IMX93%20%E4%B8%BB%E6%9D%BF%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%B5%E5%BE%AA%E4%BA%86%E4%B8%BB%E6%9D%BF%E7%9A%84%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM12181%2Fpage%2Ftopics%2Fcamera_module_rpi_cam_mipi.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM12181%2Fpage%2Ftopics%2Fcamera_module_rpi_cam_mipi.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E8%BF%9E%E6%8E%A5%E4%BA%86%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%20ONSEMI%20github%20(%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%3C%2FA%3E)%20%E9%82%A3%E9%87%8C%E6%8B%BF%E5%88%B0%E4%BA%86%20ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%EF%BC%8C%E9%87%8D%E5%91%BD%E5%90%8D%E4%BA%86%E7%84%B6%E5%90%8E%E6%8A%8A%E5%AE%83%E6%94%BE%E8%BF%9B%E4%BA%86%E4%B8%BB%E6%9D%BF%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20ls%20%2Flib%2Ffirmware%2Fimx%2Fcamera%2F%3CBR%20%2F%3Eap1302.fw%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E4%BA%86%E7%9B%B8%E6%9C%BA%EF%BC%8C%E4%BD%86%E6%97%A5%E5%BF%97%E5%92%8C%E6%89%8B%E5%86%8C%E4%B8%8A%E7%9A%84%E4%B8%8D%E4%B8%80%E6%A0%B7%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20dmesg%20%7C%20grep%20ap1302%3CBR%20%2F%3E%5B%200.341004%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%EF%BC%9A%E4%BF%AE%E6%AD%A3%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3CBR%20%2F%3E%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%20%5B%200.371040%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%200.411142%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%EF%BC%9A%E4%BF%AE%E6%AD%A3%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.433309%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%EF%BC%9A%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.464010%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3CBR%20%2F%3E%5B%200.476107%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%EF%BC%9A%E4%BF%AE%E6%AD%A3%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.495817%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%E4%BF%AE%E6%AD%A3%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%202.093316%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%202.104580%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%EF%BC%9A%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%91%84%E5%83%8F%E5%A4%B4%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%20%40imx93%20-11x11-lpddr4x-frdm%EF%BC%9A~%23%20media-ctl-p%20%3CBR%20%2F%3E%20%E6%97%A0%E6%B3%95%E6%9E%9A%E4%B8%BE%20%2Fdev%2Fmedia0%20(-2)%20root%20%40imx93%20-11x11-lpddr4x-frdm%EF%BC%9A~%23%20v4l2-ctl--list-devices%20mxc-isi-cap%EF%BC%88%E5%B9%B3%E5%8F%B0%EF%BC%9A4ae40000.isi%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2Fdev%2Fvideo0%3CBR%20%2F%3E%2Fdev%2Fvideo1%3C%2FP%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20i2cdetect%20-y%201%3CBR%20%2F%3E0%201%202%203%204%205%206%207%208%209%20a%20b%20c%20d%20e%20f%3CBR%20%2F%3E00%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E10%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E20%3A%20--%20--%20UU%20--%20--%20UU%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E30%EF%BC%9A--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E40%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E50%3A%2050%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E60%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E70%3A%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Aroot%40imx93-11x11-lpddr4x-frdm%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E9%87%8D%E6%96%B0%E6%A3%80%E6%9F%A5%E4%BA%86%E4%B8%80%E5%88%87%E3%80%82%E6%88%91%E5%8D%A1%E4%BD%8F%E4%BA%86%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E5%A5%BD%E5%8A%9E%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E7%9A%84%E8%BF%9E%E6%8E%A5%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%EF%BC%8C%E8%93%9D%E8%89%B2%E4%B8%80%E4%BE%A7%E5%BA%94%E4%B8%8E%E6%91%84%E5%83%8F%E5%A4%B4%E4%B8%80%E4%BE%A7%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388629i75417AA223BC31DB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1781136494125.png%22%20alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EZhiming_Liu_0-1781136494125.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E7%85%A7%E7%89%87%EF%BC%8C%E4%BD%86%E6%88%91%E4%B9%9F%E7%94%A8%E4%B8%87%E7%94%A8%E8%A1%A8%E6%A3%80%E6%9F%A5%E4%BA%86%E8%BF%9E%E7%BB%AD%E6%80%A7%EF%BC%8C%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%EF%BC%8CFRDM%20%E4%B8%8A%E7%9A%84%E5%BC%95%E8%84%9A%E4%B8%8E%20CAM%20%E4%B8%8A%E7%9A%84%E5%BC%95%E8%84%9A%E7%9B%B8%E9%80%9A...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388595i78F0E83F0556BC55%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RPICAMConectionBack.png%22%20alt%3D%22RPICAMConectionBack.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERPICAMConectionBack.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%8E%E5%8F%A6%E4%B8%80%E8%BE%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388594iBD7AA6D9459743E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RPICAMConection.png%22%20alt%3D%22RPICAMConection.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERPICAMConection.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E9%87%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E6%98%BE%E7%A4%BA%20RPI-CAM-MIPI%20%E5%92%8C%20FRDM93%20%E4%B9%8B%E9%97%B4%E8%BF%9E%E6%8E%A5%E7%9A%84%E7%85%A7%E7%89%87%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%26nbsp%3B%3CLI-EMOJI%20id%3D%22lia_grinning-face-with-smiling-eyes%22%20title%3D%22%3Agrinning_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E6%97%A0%E6%95%B0%E6%AC%A1%EF%BC%8C%E4%BD%86%E6%AF%8F%E6%AC%A1%E9%83%BD%E6%BC%8F%E6%8E%89%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E6%83%85%E5%86%B5%E6%9C%89%E6%89%80%E5%A5%BD%E8%BD%AC%EF%BC%8C%E4%BD%86%E7%9C%8B%E6%9D%A5%E6%88%91%E8%BF%98%E6%98%AF%E9%81%87%E5%88%B0%E4%BA%86.fw%E6%96%87%E4%BB%B6%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20dmesg%20%7C%20grep%20ap1302%3CBR%20%2F%3E%5B%200.340881%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.370918%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E7%9B%B8%E5%85%B3%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.411017%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.433185%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.463890%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E7%9B%B8%E5%85%B3%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.475987%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.495704%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E7%9B%B8%E5%85%B3%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%202.098808%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E4%B9%8B%E9%97%B4%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%202.110107%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%E5%B7%B2%E4%BF%AE%E5%A4%8D%E4%B8%8E%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%2010.757527%5D%20ap1302%202-003c%3A%20%E7%9B%B4%E6%8E%A5%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%20ap1302_ar0144_single_fw.bin%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20-2%3CBR%20%2F%3E%5B%2010.757549%5D%20ap1302%202-003c%3A%20%E5%B0%86%E5%9B%9E%E9%80%80%E5%88%B0%20sysfs%20%E5%A4%87%E7%94%A8%E6%96%B9%E6%A1%88%EF%BC%9Aap1302_ar0144_single_fw.bin%3CBR%20%2F%3E%5B%2010.770396%5D%20ap1302%202-003c%EF%BC%9A%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%9A%20-2%3CBR%20%2F%3E%5B%2010.818467%5D%20ap1302%202-003c%3A%20%E4%BD%BF%E7%94%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20ap1302%20%E8%BF%9B%E8%A1%8C%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20-2%3CBR%20%2F%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20media-ctl%20-p%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E6%9E%9A%E4%B8%BE%20%2Fdev%2Fmedia0%20(-2)%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Aroot%40imx93-11x11-lpddr4x-frdm%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%3C%2FA%3E%3CBR%20%2F%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20ls%20%2Flib%2Ffirmware%2Fimx%2Fcamera%2F%3CBR%20%2F%3Eap1302.fw%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EONS%20EM%20I%20GitHub%20%E4%B8%8A%E7%9A%84%20ap1302_60fps_ar0144_27M_2Lane_awb_tuning.%E6%96%87%E4%BB%B6%E6%98%AF%E5%90%A6%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%3C%2FA%3E%3CSPAN%3E%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%20%40jventura%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%20%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E8%AF%B7%E5%B0%9D%E8%AF%95%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FRM00293%2Fpage%2Ftopics%2Far0144.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%20%E4%B8%AD%E7%9A%84%E4%BB%A5%E4%B8%8B%E5%BB%BA%E8%AE%AE%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22ph%20codeph%22%3Eap1302_ar0144_single_fw.bin%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%E3%80%82%E5%B0%86%E5%85%B6%E6%94%BE%E7%BD%AE%E5%9C%A8%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22ph%20codeph%22%3E%2Flib%2Ffirmware%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%8B%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2381436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2381436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B0%A2%E8%B0%A2%E5%BF%97%E6%98%8E%EF%BC%8C%E6%88%90%E5%8A%9F%E4%BA%86%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8D%E8%BF%87%EF%BC%8CGopoint%20DMS%20%E7%9A%84%E6%BC%94%E7%A4%BA%E7%89%88%E5%8D%B4%E6%97%A0%E6%B3%95%E6%98%BE%E7%A4%BA%E2%80%A6%E2%80%A6%E6%88%91%E8%A7%89%E5%BE%97%E5%8F%AF%E8%83%BD%E6%98%AF%E5%AA%92%E4%BD%93%E7%AE%A1%E9%81%93%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BC%9A%E6%9F%A5%E6%9F%A5%E7%9C%8B%E3%80%82%3C%2FLINGO-BODY%3E
