FRDM-IMX93 - UUU encounters LIBUSB error
dmarks_ls
Senior Contributor II
Hi there,
I'm hoping this is a newbie problem that has a newbie solution.  I'm trying to flash a FRDM-IMX93 board using the latest UUU (Release uuu_1.5.233), and whether I use a Windows 11 host or a Linux (Ubuntu 24.04.03 LTS) host, I always get a LIBUSB error immediately.
On my FRDM-IMX93, I have a chip marked "MIMX9352 CVVXMAB 1P87F SBBD2427F".  Breaking down the part number, it's an IMX93 with industrial temp (C), 11x11 BGA (VV), no add'l info (X), 1.7 GHz (M), no special fuse (A), and silicon rev 2.0 (B).  Based on other docs I've seen (e.g. Digi), xxxxxxB indicates step A1 silicon, while xxxxxxA would indicate step A0 silicon.  Thus, I don't appear (hopefully) to have the issue of the latest UUU not supporting the early-rev A0 silicon.
I created my repo:
repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-walnascar -mimx-6.12.34-2.1.0.xml
I set up my build:
DISTRO=fsl-imx-xwayland MACHINE=imx93-11x11-lpddr4x-frdm source imx-setup-release.sh -b build
And I ran my build:
bitbake imx-image-multimedia
And three hours later, I had a successful build (just warnings about ftp.gnu.org mirrors and TMPDIR usage).
So I went into the images directory and tried to program the FRDM-IMX93 board.  I flipped the DIP switches to 0001 (serial bootloader, Cortex-A55), and I verified that I had a connected board:
dmarks@Perseus:~/yocto/frdm-imx93/build/tmp/deploy/images/imx93-11x11-lpddr4x-frdm$ sudo uuu -lsusb
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.233-0-g79ce7d2
Connected Known USB Devices
Path Chip Pro Vid Pid BcdVersion Serial_no
1:12 MX93 SDPS: 0x1FC9 0x014E 0x0001 393792579FA24D4E
And I issued the UUU command to flash the device (with verbosity on), and got this:
dmarks@Perseus:~/yocto/frdm-imx93/build/tmp/deploy/images/imx93-11x11-lpddr4x-frdm$ sudo uuu -V -b sd u-boot-sd-2025.04-r0.bin
Build in config:
	Pctl	 Chip		 Vid	 Pid	 BcdVersion	 Serial_No
	SDPS:	 MX8QXP		 0x1fc9	 0x012f	 [0x0002..0xffff]
	SDPS:	 MX8QM		 0x1fc9	 0x0129	 [0x0002..0xffff]
	SDPS:	 MX8DXL		 0x1fc9	 0x0147
	SDPS:	 MX28		 0x15a2	 0x004f
	SDPS:	 MX815		 0x1fc9	 0x013e
	SDPS:	 MX865		 0x1fc9	 0x0146
	SDPS:	 MX8ULP		 0x1fc9	 0x014a
	SDPS:	 MX8ULP		 0x1fc9	 0x014b
	SDPS:	 MX93		 0x1fc9	 0x014e
	SDPS:	 MX91		 0x1fc9	 0x0159
	SDPS:	 MX95		 0x1fc9	 0x015d
	SDPS:	 MX95		 0x1fc9	 0x015c
	SDPS:	 MX943		 0x1fc9	 0x0027
	SDP:	 MX7D		 0x15a2	 0x0076
	SDP:	 MX6Q		 0x15a2	 0x0054
	SDP:	 MX6D		 0x15a2	 0x0061
	SDP:	 MX6SL		 0x15a2	 0x0063
	SDP:	 MX6SX		 0x15a2	 0x0071
	SDP:	 MX6UL		 0x15a2	 0x007d
	SDP:	 MX6ULL		 0x15a2	 0x0080
	SDP:	 MX6SLL		 0x1fc9	 0x0128
	SDP:	 MX7ULP		 0x1fc9	 0x0126
	SDP:	 MXRT106X	 0x1fc9	 0x0135
	SDP:	 MX8MM		 0x1fc9	 0x0134
	SDP:	 MX8MQ		 0x1fc9	 0x012b
	SDPU:	 SPL		 0x0525	 0xb4a4	 [0x0000..0x04ff]
	SDPV:	 SPL1		 0x0525	 0xb4a4	 [0x0500..0x9998]
	SDPV:	 SPL1		 0x1fc9	 0x0151	 [0x0500..0x9998]
	SDPU:	 SPL		 0x0525	 0xb4a4	 [0x9999..0x9999]
	SDPU:	 SPL		 0x3016	 0x1001	 [0x0000..0x04ff]
	SDPV:	 SPL1		 0x3016	 0x1001	 [0x0500..0x9998]
	FBK:	 		 0x066f	 0x9afe
	FBK:	 		 0x066f	 0x9bff
	FBK:	 		 0x1fc9	 0x0153
	FB:	 		 0x0525	 0xa4a5
	FB:	 		 0x18d1	 0x0d02
	FB:	 		 0x3016	 0x0001
	FB:	 		 0x1fc9	 0x0152
	FB:	 		 0x0483	 0x0afb
Run built-in script:
uuu_version 1.2.39
# @_flash.bin            | bootloader
# @_image   [_flash.bin] | image burn to emmc, default is the same as bootloader
# This command will be run when i.MX6/7 i.MX8MM, i.MX8MQ
SDP: boot -f u-boot-sd-2025.04-r0.bin
# This command will be run when ROM support stream mode
# i.MX8QXP, i.MX8QM
SDPS: boot -f u-boot-sd-2025.04-r0.bin
# These commands will be run when use SPL and will be skipped if no spl
# SDPU will be deprecated. please use SDPV instead of SDPU
SDPU: delay 1000
SDPU: write -f u-boot-sd-2025.04-r0.bin -offset 0x57c00
SDPU: jump
# if (SPL support SDPV)
SDPV: delay 1000
SDPV: write -f u-boot-sd-2025.04-r0.bin -skipspl
SDPV: jump
FB: ucmd setenv fastboot_dev mmc
FB: ucmd setenv mmcdev ${sd_dev}
FB: ucmd mmc dev ${sd_dev}
FB: flash bootloader u-boot-sd-2025.04-r0.bin
FB: Done
Wait for Known USB Device Appear...
New USB Device Attached at 1:12-393792579FA24D4E
1:12-393792579FA24D4E>Start Cmd:SDPS: boot -f u-boot-sd-2025.04-r0.bin
1:12-393792579FA24D4E>Fail HID(W): LIBUSB_ERROR_IO (-1)(0.006s)
Rebooting the FRDM board did nothing to change this.  Also, switching to a Windows host did nothing to change this.
C:\>uuu -lsusb
        2:1111   MX93    SDPS:   0x1FC9 0x014E   0x0001  393792579FA24D4E
C:\>uuu -b sd u-boot-sd-2025.04-r0.bin
Success 0    Failure 1
2:1111-39379 1/ 1 [HID(W): LIBUSB_ERROR_PIPE (-9)        ] SDPS: boot -f u-boot-sd-2025.04-r0.bin
So, in summary, I'm 99% sure I have A1 silicon on my FRDM-IMX93, I built my image using the commands above on a supported Linux host, I've verified the presence of the serial downloader, but UUU just refuses to run on Linux or Windows, and the error message is rather unhelpful.
Ideas?
Dana M.
Harvey021
You can use the command line:
uuu -b emmc_all imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot imx-image-multimedia-imx93-11x11-lpddr4x-frdm.rootfs-20251021183432.wic.zst
The UUU Guide with more details can help for you.
Harvey
Harvey021
Have you tried to find a bootloader file like - imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot?
if so, try the way: uuu -b sd imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot
Harvey
dmarks_ls
OK, so that appeared to succeed (though it doesn't exit, it just loads and sits there):
C:\>uuu -b sd imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot
Success 0    Failure 0
2:1111-39379 1/ 1 [=================100%=================] SDPS: boot -f imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot
And I do see U-Boot come up on the debug port (log attached).  So UUU is at least functional.  It apparently doesn't matter whether I have an SD card inserted or not; presumably it's booting from internal RAM.
For this Yocto build and the FRDM-IMX93, what is the correct command line to fully reprogram the eMMC flash with U-Boot and a root filesystem image?  (I've attached a directory listing of all of my Yocto build artifacts/images.)
Harvey021
Harvey
Siddhesh_Nayak
Hi @Harvey021 ,
I have been attempting to flash a Yocto image for the i.MX93 FRDM board along with a custom recipe, but I’ve been unsuccessful so far.
To rule out any issues with my custom build, I tried using the demo images available on the NXP portal; however, I am encountering the same problem.
During the flashing process, I consistently see the following error:
2:3->Fail HID(W): LIBUSB_ERROR_TIMEOUT (-7) (20.02s)
I also followed the commands you suggested earlier as a potential solution, but I’m still unable to flash the image, and the process fails with the same timeout error.
C:\_ddm\Tools\UUU>uuu -V -b sd_all "C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-boot-imx93frdm-ecc.bin-flash_singleboot" "C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-image-full-imx93frdm.rootfs.wic.zst"
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.243-0-g230f1b1
Build in config:
        SDPS:    MX952           0x1fc9  0x0028
        FBK:                     0x066f  0x9afe
        FBK:                     0x066f  0x9bff
        FBK:                     0x1fc9  0x0153
        FB:                      0x0525  0xa4a5
        FB:                      0x18d1  0x0d02
        FB:                      0x3016  0x0001
        FB:                      0x1fc9  0x0152
        FB:                      0x0483  0x0afb
uuu_version 1.4.149
# @_flash.bin            | bootloader, which can extract from wic image
# @_image   [_flash.bin] | wic image burn to emmc.
SDP: boot -f C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-boot-imx93frdm-ecc.bin-flash_singleboot -scanlimited 0x800000
# i.MX8QXP, i.MX8QM
SDPS: boot -scanterm -f C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-boot-imx93frdm-ecc.bin-flash_singleboot -scanlimited 0x800000
SDPU: delay 1000
SDPU: write -f C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-boot-imx93frdm-ecc.bin-flash_singleboot -offset 0x57c00 -scanlimited 0x800000
SDPU: jump -scanlimited 0x800000
SDPV: delay 1000
SDPV: write -f C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-boot-imx93frdm-ecc.bin-flash_singleboot -skipspl -scanterm -scanlimited 0x800000
SDPV: jump -scanlimited 0x800000
FB: flash -raw2sparse all C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-image-full-imx93frdm.rootfs.wic.zst/*
FB: flash -scanterm -scanlimited 0x800000 bootloader C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-boot-imx93frdm-ecc.bin-flash_singleboot
FB: done
New USB Device Attached at 2:3-
2:3->Start Cmd:SDPS: boot -scanterm -f C:\Users\nxf80713\Downloads\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\LF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93\imx-boot-imx93frdm-ecc.bin-flash_singleboot -scanlimited 0x800000
2:3->Fail HID(W): LIBUSB_ERROR_TIMEOUT (-7)(20.02s)
libusb: warning [libusb_exit] device 1.29 still referenced
libusb: warning [libusb_exit] device 2.10 still referenced
libusb: warning [libusb_exit] device 2.0 still referenced
libusb: warning [libusb_exit] device 2.31 still referenced
libusb: warning [libusb_exit] device 2.33 still referenced
libusb: warning [libusb_exit] device 2.34 still referenced
libusb: warning [libusb_exit] device 1.28 still referenced
libusb: warning [libusb_exit] device 1.0 still referenced
dmarks_ls
Thank you, that command worked on my FRDM board.  I was unclear as to what the correct U-Boot image was to use for the bootloader; I had mistakenly thought it was "u-boot-sd-2025.04-r0.bin".  Appreciate the help.
Dana M.
%3CLINGO-SUB%20id%3D%22lingo-sub-2192915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-IMX93%20-%20UUU%20encounters%20LIBUSB%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20there%2C%3C%2FP%3E%3CP%3EI'm%20hoping%20this%20is%20a%20newbie%20problem%20that%20has%20a%20newbie%20solution.%26nbsp%3B%20I'm%20trying%20to%20flash%20a%20FRDM-IMX93%20board%20using%20the%20latest%20UUU%20(Release%20uuu_1.5.233)%2C%20and%20whether%20I%20use%20a%20Windows%2011%20host%20or%20a%20Linux%20(Ubuntu%2024.04.03%20LTS)%20host%2C%20I%20always%20get%20a%20LIBUSB%20error%20immediately.%3C%2FP%3E%3CP%3EOn%20my%20FRDM-IMX93%2C%20I%20have%20a%20chip%20marked%20%22MIMX9352%20CVVXMAB%201P87F%20SBBD2427F%22.%26nbsp%3B%20Breaking%20down%20the%20part%20number%2C%20it's%20an%20IMX93%20with%20industrial%20temp%20(C)%2C%2011x11%20BGA%20(VV)%2C%20no%20add'l%20info%20(X)%2C%201.7%20GHz%20(M)%2C%20no%20special%20fuse%20(A)%2C%20and%20silicon%20rev%202.0%20(B).%26nbsp%3B%20Based%20on%20other%20docs%20I've%20seen%20(e.g.%20Digi)%2C%20xxxxxxB%20indicates%20step%20A1%20silicon%2C%20while%20xxxxxxA%20would%20indicate%20step%20A0%20silicon.%26nbsp%3B%20Thus%2C%20I%20don't%20appear%20(hopefully)%20to%20have%20the%20issue%20of%20the%20latest%20UUU%20not%20supporting%20the%20early-rev%20A0%20silicon.%3C%2FP%3E%3CP%3EI%20created%20my%20repo%3A%3C%2FP%3E%3CPRE%3Erepo%20init%20-u%20https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%20-b%20imx-linux-walnascar%20-mimx-6.12.34-2.1.0.xml%3C%2FPRE%3E%3CP%3EI%20set%20up%20my%20build%3A%3C%2FP%3E%3CPRE%3EDISTRO%3Dfsl-imx-xwayland%20MACHINE%3Dimx93-11x11-lpddr4x-frdm%20source%20imx-setup-release.sh%20-b%20build%3C%2FPRE%3E%3CP%3EAnd%20I%20ran%20my%20build%3A%3C%2FP%3E%3CPRE%3Ebitbake%20imx-image-multimedia%3C%2FPRE%3E%3CP%3EAnd%20three%20hours%20later%2C%20I%20had%20a%20successful%20build%20(just%20warnings%20about%20ftp.gnu.org%20mirrors%20and%20TMPDIR%20usage).%3C%2FP%3E%3CP%3ESo%20I%20went%20into%20the%20images%20directory%20and%20tried%20to%20program%20the%20FRDM-IMX93%20board.%26nbsp%3B%20I%20flipped%20the%20DIP%20switches%20to%200001%20(serial%20bootloader%2C%20Cortex-A55)%2C%20and%20I%20verified%20that%20I%20had%20a%20connected%20board%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Edmarks%40Perseus%3A~%2Fyocto%2Ffrdm-imx93%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2Fimx93-11x11-lpddr4x-frdm%24%20sudo%20uuu%20-lsusb%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.233-0-g79ce7d2%0A%0AConnected%20Known%20USB%20Devices%0APath%20Chip%20Pro%20Vid%20Pid%20BcdVersion%20Serial_no%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A1%3A12%20MX93%20SDPS%3A%200x1FC9%200x014E%200x0001%20393792579FA24D4E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EAnd%20I%20issued%20the%20UUU%20command%20to%20flash%20the%20device%20(with%20verbosity%20on)%2C%20and%20got%20this%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Edmarks%40Perseus%3A~%2Fyocto%2Ffrdm-imx93%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2Fimx93-11x11-lpddr4x-frdm%24%20sudo%20uuu%20-V%20-b%20sd%20u-boot-sd-2025.04-r0.bin%20%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.233-0-g79ce7d2%0A%0ABuild%20in%20config%3A%0A%09Pctl%09%20Chip%09%09%20Vid%09%20Pid%09%20BcdVersion%09%20Serial_No%0A%09%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%09SDPS%3A%09%20MX8QXP%09%09%200x1fc9%09%200x012f%09%20%5B0x0002..0xffff%5D%0A%09SDPS%3A%09%20MX8QM%09%09%200x1fc9%09%200x0129%09%20%5B0x0002..0xffff%5D%0A%09SDPS%3A%09%20MX8DXL%09%09%200x1fc9%09%200x0147%0A%09SDPS%3A%09%20MX28%09%09%200x15a2%09%200x004f%0A%09SDPS%3A%09%20MX815%09%09%200x1fc9%09%200x013e%0A%09SDPS%3A%09%20MX865%09%09%200x1fc9%09%200x0146%0A%09SDPS%3A%09%20MX8ULP%09%09%200x1fc9%09%200x014a%0A%09SDPS%3A%09%20MX8ULP%09%09%200x1fc9%09%200x014b%0A%09SDPS%3A%09%20MX93%09%09%200x1fc9%09%200x014e%0A%09SDPS%3A%09%20MX91%09%09%200x1fc9%09%200x0159%0A%09SDPS%3A%09%20MX95%09%09%200x1fc9%09%200x015d%0A%09SDPS%3A%09%20MX95%09%09%200x1fc9%09%200x015c%0A%09SDPS%3A%09%20MX943%09%09%200x1fc9%09%200x0027%0A%09SDP%3A%09%20MX7D%09%09%200x15a2%09%200x0076%0A%09SDP%3A%09%20MX6Q%09%09%200x15a2%09%200x0054%0A%09SDP%3A%09%20MX6D%09%09%200x15a2%09%200x0061%0A%09SDP%3A%09%20MX6SL%09%09%200x15a2%09%200x0063%0A%09SDP%3A%09%20MX6SX%09%09%200x15a2%09%200x0071%0A%09SDP%3A%09%20MX6UL%09%09%200x15a2%09%200x007d%0A%09SDP%3A%09%20MX6ULL%09%09%200x15a2%09%200x0080%0A%09SDP%3A%09%20MX6SLL%09%09%200x1fc9%09%200x0128%0A%09SDP%3A%09%20MX7ULP%09%09%200x1fc9%09%200x0126%0A%09SDP%3A%09%20MXRT106X%09%200x1fc9%09%200x0135%0A%09SDP%3A%09%20MX8MM%09%09%200x1fc9%09%200x0134%0A%09SDP%3A%09%20MX8MQ%09%09%200x1fc9%09%200x012b%0A%09SDPU%3A%09%20SPL%09%09%200x0525%09%200xb4a4%09%20%5B0x0000..0x04ff%5D%0A%09SDPV%3A%09%20SPL1%09%09%200x0525%09%200xb4a4%09%20%5B0x0500..0x9998%5D%0A%09SDPV%3A%09%20SPL1%09%09%200x1fc9%09%200x0151%09%20%5B0x0500..0x9998%5D%0A%09SDPU%3A%09%20SPL%09%09%200x0525%09%200xb4a4%09%20%5B0x9999..0x9999%5D%0A%09SDPU%3A%09%20SPL%09%09%200x3016%09%200x1001%09%20%5B0x0000..0x04ff%5D%0A%09SDPV%3A%09%20SPL1%09%09%200x3016%09%200x1001%09%20%5B0x0500..0x9998%5D%0A%09FBK%3A%09%20%09%09%200x066f%09%200x9afe%0A%09FBK%3A%09%20%09%09%200x066f%09%200x9bff%0A%09FBK%3A%09%20%09%09%200x1fc9%09%200x0153%0A%09FB%3A%09%20%09%09%200x0525%09%200xa4a5%0A%09FB%3A%09%20%09%09%200x18d1%09%200x0d02%0A%09FB%3A%09%20%09%09%200x3016%09%200x0001%0A%09FB%3A%09%20%09%09%200x1fc9%09%200x0152%0A%09FB%3A%09%20%09%09%200x0483%09%200x0afb%0A%0ARun%20built-in%20script%3A%0A%20%0Auuu_version%201.2.39%0A%0A%23%20%40_flash.bin%20%20%20%20%20%20%20%20%20%20%20%20%7C%20bootloader%0A%23%20%40_image%20%20%20%5B_flash.bin%5D%20%7C%20image%20burn%20to%20emmc%2C%20default%20is%20the%20same%20as%20bootloader%0A%0A%23%20This%20command%20will%20be%20run%20when%20i.MX6%2F7%20i.MX8MM%2C%20i.MX8MQ%0ASDP%3A%20boot%20-f%20u-boot-sd-2025.04-r0.bin%0A%0A%23%20This%20command%20will%20be%20run%20when%20ROM%20support%20stream%20mode%0A%23%20i.MX8QXP%2C%20i.MX8QM%0ASDPS%3A%20boot%20-f%20u-boot-sd-2025.04-r0.bin%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20SDPU%20will%20be%20deprecated.%20please%20use%20SDPV%20instead%20of%20SDPU%0A%23%20%7B%0ASDPU%3A%20delay%201000%0ASDPU%3A%20write%20-f%20u-boot-sd-2025.04-r0.bin%20-offset%200x57c00%0ASDPU%3A%20jump%0A%23%20%7D%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20if%20(SPL%20support%20SDPV)%0A%23%20%7B%0ASDPV%3A%20delay%201000%0ASDPV%3A%20write%20-f%20u-boot-sd-2025.04-r0.bin%20-skipspl%0ASDPV%3A%20jump%0A%23%20%7D%0A%0AFB%3A%20ucmd%20setenv%20fastboot_dev%20mmc%0AFB%3A%20ucmd%20setenv%20mmcdev%20%24%7Bsd_dev%7D%0AFB%3A%20ucmd%20mmc%20dev%20%24%7Bsd_dev%7D%0AFB%3A%20flash%20bootloader%20u-boot-sd-2025.04-r0.bin%0AFB%3A%20Done%0A%0A%0AWait%20for%20Known%20USB%20Device%20Appear...%0ANew%20USB%20Device%20Attached%20at%201%3A12-393792579FA24D4E%0A1%3A12-393792579FA24D4E%26gt%3BStart%20Cmd%3ASDPS%3A%20boot%20-f%20u-boot-sd-2025.04-r0.bin%0A1%3A12-393792579FA24D4E%26gt%3BFail%20HID(W)%3A%20LIBUSB_ERROR_IO%20(-1)(0.006s)%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3ERebooting%20the%20FRDM%20board%20did%20nothing%20to%20change%20this.%26nbsp%3B%20Also%2C%20switching%20to%20a%20Windows%20host%20did%20nothing%20to%20change%20this.%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3EC%3A%5C%26gt%3Buuu%20-lsusb%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.233-0-g79ce7d2%0A%0AConnected%20Known%20USB%20Devices%0A%20%20%20%20%20%20%20%20Path%20%20%20%20%20Chip%20%20%20%20Pro%20%20%20%20%20Vid%20%20%20%20%20Pid%20%20%20%20%20BcdVersion%20%20%20%20%20%20Serial_no%0A%20%20%20%20%20%20%20%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%20%20%20%20%20%20%20%202%3A1111%20%20%20MX93%20%20%20%20SDPS%3A%20%20%200x1FC9%200x014E%20%20%200x0001%20%20393792579FA24D4E%0A%0AC%3A%5C%26gt%3Buuu%20-b%20sd%20u-boot-sd-2025.04-r0.bin%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.233-0-g79ce7d2%0A%0ASuccess%200%20%20%20%20Failure%201%0A%0A%0A2%3A1111-39379%201%2F%201%20%5BHID(W)%3A%20LIBUSB_ERROR_PIPE%20(-9)%20%20%20%20%20%20%20%20%5D%20SDPS%3A%20boot%20-f%20u-boot-sd-2025.04-r0.bin%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3ESo%2C%20in%20summary%2C%20I'm%2099%25%20sure%20I%20have%20A1%20silicon%20on%20my%20FRDM-IMX93%2C%20I%20built%20my%20image%20using%20the%20commands%20above%20on%20a%20supported%20Linux%20host%2C%20I've%20verified%20the%20presence%20of%20the%20serial%20downloader%2C%20but%20UUU%20just%20refuses%20to%20run%20on%20Linux%20or%20Windows%2C%20and%20the%20error%20message%20is%20rather%20unhelpful.%3C%2FP%3E%3CP%3EIdeas%3F%3C%2FP%3E%3CP%3EDana%20M.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2192915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20-%20UUU%20encounters%20LIBUSB%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%2C%20that%20command%20worked%20on%20my%20FRDM%20board.%26nbsp%3B%20I%20was%20unclear%20as%20to%20what%20the%20correct%20U-Boot%20image%20was%20to%20use%20for%20the%20bootloader%3B%20I%20had%20mistakenly%20thought%20it%20was%20%22u-boot-sd-2025.04-r0.bin%22.%26nbsp%3B%20Appreciate%20the%20help.%3C%2FP%3E%3CP%3EDana%20M.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20-%20UUU%20encounters%20LIBUSB%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20use%20the%20command%20line%3A%26nbsp%3B%3C%2FP%3E%0A%3CP%3Euuu%20-b%20emmc_all%20imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot%26nbsp%3Bimx-image-multimedia-imx93-11x11-lpddr4x-frdm.rootfs-20251021183432.wic.zst%3C%2FP%3E%0A%3CP%3EThe%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmfgtools%2Freleases%2Fdownload%2Fuuu_1.5.233%2FUUU.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUUU%20Guide%3C%2FA%3E%26nbsp%3Bwith%20more%20details%20can%20help%20for%20you.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20-%20UUU%20encounters%20LIBUSB%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK%2C%20so%20that%20appeared%20to%20succeed%20(though%20it%20doesn't%20exit%2C%20it%20just%20loads%20and%20sits%20there)%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3EC%3A%5C%26gt%3Buuu%20-b%20sd%20imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.233-0-g79ce7d2%0A%0ASuccess%200%20%20%20%20Failure%200%0A%0A%0A2%3A1111-39379%201%2F%201%20%5B%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D100%25%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%5D%20SDPS%3A%20boot%20-f%20imx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EAnd%20I%20do%20see%20U-Boot%20come%20up%20on%20the%20debug%20port%20(log%20attached).%26nbsp%3B%20So%20UUU%20is%20at%20least%20functional.%26nbsp%3B%20It%20apparently%20doesn't%20matter%20whether%20I%20have%20an%20SD%20card%20inserted%20or%20not%3B%20presumably%20it's%20booting%20from%20internal%20RAM.%3C%2FP%3E%3CP%3EFor%20this%20Yocto%20build%20and%20the%20FRDM-IMX93%2C%20what%20is%20the%20correct%20command%20line%20to%20fully%20reprogram%20the%20eMMC%20flash%20with%20U-Boot%20and%20a%20root%20filesystem%20image%3F%26nbsp%3B%20(I've%20attached%20a%20directory%20listing%20of%20all%20of%20my%20Yocto%20build%20artifacts%2Fimages.)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20-%20UUU%20encounters%20LIBUSB%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EHave%20you%20tried%20to%20find%20a%20bootloader%20file%20like%20-%26nbsp%3Bimx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot%3F%3C%2FP%3E%0A%3CP%3Eif%20so%2C%20try%20the%20way%3A%20uuu%20-b%20sd%26nbsp%3Bimx-boot-imx93-11x11-lpddr4x-frdm-sd.bin-flash_singleboot%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20-%20UUU%20encounters%20LIBUSB%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192970%22%20target%3D%22_blank%22%3E%40Harvey021%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%0A%3CP%3EI%20have%20been%20attempting%20to%20flash%20a%20Yocto%20image%20for%20the%20i.MX93%20FRDM%20board%20along%20with%20a%20custom%20recipe%2C%20but%20I%E2%80%99ve%20been%20unsuccessful%20so%20far.%3C%2FP%3E%0A%3CP%3ETo%20rule%20out%20any%20issues%20with%20my%20custom%20build%2C%20I%20tried%20using%20the%20demo%20images%20available%20on%20the%20NXP%20portal%3B%20however%2C%20I%20am%20encountering%20the%20same%20problem.%3C%2FP%3E%0A%3CP%3EDuring%20the%20flashing%20process%2C%20I%20consistently%20see%20the%20following%20error%3A%3C%2FP%3E%0A%3CPRE%3E%3CCODE%3E2%3A3-%26gt%3BFail%20HID(W)%3A%20LIBUSB_ERROR_TIMEOUT%20(-7)%20(20.02s)%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EI%20also%20followed%20the%20commands%20you%20suggested%20earlier%20as%20a%20potential%20solution%2C%20but%20I%E2%80%99m%20still%20unable%20to%20flash%20the%20image%2C%20and%20the%20process%20fails%20with%20the%20same%20timeout%20error.%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3EC%3A%5C_ddm%5CTools%5CUUU%26gt%3Buuu%20-V%20-b%20sd_all%20%22C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-boot-imx93frdm-ecc.bin-flash_singleboot%22%20%22C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-image-full-imx93frdm.rootfs.wic.zst%22%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.243-0-g230f1b1%0A%0ABuild%20in%20config%3A%0A%20%20%20%20%20%20%20%20Pctl%20%20%20%20%20Chip%20%20%20%20%20%20%20%20%20%20%20%20Vid%20%20%20%20%20Pid%20%20%20%20%20BcdVersion%20%20%20%20%20%20Serial_No%0A%20%20%20%20%20%20%20%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8QXP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x012f%20%20%5B0x0002..0xffff%5D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8QM%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0129%20%20%5B0x0002..0xffff%5D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8DXL%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0147%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX28%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x004f%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX815%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x013e%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX865%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0146%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014a%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014b%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX93%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014e%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX91%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0159%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX95%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x015d%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX95%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x015c%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX943%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0027%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX952%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0028%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX7D%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0076%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6Q%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0054%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6D%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0061%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SL%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0063%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SX%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0071%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6UL%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x007d%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6ULL%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0080%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SLL%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0128%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX7ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0126%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MXRT106X%20%20%20%20%20%20%20%200x1fc9%20%200x0135%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX8MM%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0134%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX8MQ%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x012b%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x0000..0x04ff%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0151%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x9999..0x9999%5D%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x1001%20%20%5B0x0000..0x04ff%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x1001%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x066f%20%200x9afe%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x066f%20%200x9bff%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0153%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xa4a5%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x18d1%20%200x0d02%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x0001%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0152%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0483%20%200x0afb%0A%0ARun%20built-in%20script%3A%0A%0Auuu_version%201.4.149%0A%0A%23%20%40_flash.bin%20%20%20%20%20%20%20%20%20%20%20%20%7C%20bootloader%2C%20which%20can%20extract%20from%20wic%20image%0A%23%20%40_image%20%20%20%5B_flash.bin%5D%20%7C%20wic%20image%20burn%20to%20emmc.%0A%0A%0A%23%20This%20command%20will%20be%20run%20when%20i.MX6%2F7%20i.MX8MM%2C%20i.MX8MQ%0ASDP%3A%20boot%20-f%20C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-boot-imx93frdm-ecc.bin-flash_singleboot%20-scanlimited%200x800000%0A%0A%23%20This%20command%20will%20be%20run%20when%20ROM%20support%20stream%20mode%0A%23%20i.MX8QXP%2C%20i.MX8QM%0ASDPS%3A%20boot%20-scanterm%20-f%20C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-boot-imx93frdm-ecc.bin-flash_singleboot%20-scanlimited%200x800000%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20SDPU%20will%20be%20deprecated.%20please%20use%20SDPV%20instead%20of%20SDPU%0A%23%20%7B%0ASDPU%3A%20delay%201000%0ASDPU%3A%20write%20-f%20C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-boot-imx93frdm-ecc.bin-flash_singleboot%20-offset%200x57c00%20-scanlimited%200x800000%0ASDPU%3A%20jump%20-scanlimited%200x800000%0A%23%20%7D%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20if%20(SPL%20support%20SDPV)%0A%23%20%7B%0ASDPV%3A%20delay%201000%0ASDPV%3A%20write%20-f%20C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-boot-imx93frdm-ecc.bin-flash_singleboot%20-skipspl%20-scanterm%20-scanlimited%200x800000%0ASDPV%3A%20jump%20-scanlimited%200x800000%0A%23%20%7D%0A%0AFB%3A%20ucmd%20setenv%20fastboot_dev%20mmc%0AFB%3A%20ucmd%20setenv%20mmcdev%20%24%7Bsd_dev%7D%0AFB%3A%20ucmd%20mmc%20dev%20%24%7Bsd_dev%7D%0AFB%3A%20flash%20-raw2sparse%20all%20C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-image-full-imx93frdm.rootfs.wic.zst%2F*%0AFB%3A%20flash%20-scanterm%20-scanlimited%200x800000%20bootloader%20C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-boot-imx93frdm-ecc.bin-flash_singleboot%0AFB%3A%20done%0A%0A%0AWait%20for%20Known%20USB%20Device%20Appear...%0ANew%20USB%20Device%20Attached%20at%202%3A3-%0A2%3A3-%26gt%3BStart%20Cmd%3ASDPS%3A%20boot%20-scanterm%20-f%20C%3A%5CUsers%5Cnxf80713%5CDownloads%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5CLF_v6.6.36-2.1.0_images_FRDM_3.0_i.MX93%5Cimx-boot-imx93frdm-ecc.bin-flash_singleboot%20-scanlimited%200x800000%0A2%3A3-%26gt%3BFail%20HID(W)%3A%20LIBUSB_ERROR_TIMEOUT%20(-7)(20.02s)%0A%0A%0A%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%201.29%20still%20referenced%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%202.10%20still%20referenced%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%202.0%20still%20referenced%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%202.31%20still%20referenced%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%202.33%20still%20referenced%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%202.34%20still%20referenced%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%201.28%20still%20referenced%0Alibusb%3A%20warning%20%5Blibusb_exit%5D%20device%201.0%20still%20referenced%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
