Ethos-u delegate
Ethos-u delegate
Mohan51
Hi, I am using IMX93 board and i want to run my object detection model on NPU.for that i need libethosu.so delegate..how to create that delegate.Previously I created Vx delegate for IMX8M family processors by following Machine learning guide(https://www.nxp.com/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf). but i am unable to build ethos-u delegate..could you please assist me.
Mohan51
Hi @Manuel_Salas ..i didn't found any libethosu_delegate.so in your latest BSP under /usr/lib ..i.e Linux6.6.3_1.0.0
Manuel_Salas
Hello @Mohan51
Could you please double check? This is from the i.MX93EVK and BSP 6.6.3:
root@imx93evk:~# uname -a
Linux imx93evk 6.6.3-lts-next-gccf0a99701a7 #1 SMP PREEMPT Thu Feb 29 08:37:44 UTC 2024 aarch64 GNU/Linux
root@imx93evk:~# ls /usr/lib/ |grep libethosu_delegate
root@imx93evk:~#
Best regards.
Salas.
bighero77
hi,   salas
       would you please tell me how to find the c/c++ code to use ethosu delegate?
       my boss do not like use objection dection(on ethosu delegate ) by python.
       can I get the C/C++ code to do this job (with ethosu delegate )
       or,
        in fact.  up to now , we cannot drive ethosu delegate by c/c++
Manuel_Salas
Hello @bighero77
Hope you are doing very well.
You mean this repo?
Salas.
Mohan51
@Manuel_Salas  I didn't found any libethosu_delegate in /usr/lib.I am attaching the output for your reference.
Manuel_Salas
Hello @Mohan51
Did you flashed the full image from our official BSP?
Best regards.
Salas.
Mohan51
@Manuel_Salas yes I flashed the full image.and i downloaded the image from this url(https://www.nxp.com/webapp/sps/download/license.jsp?colCode=L6.6.3_1.0.0_MX93&appType=file1&DOWNLOAD...) i.e IMX93 EVK QSB.
Manuel_Salas
@Mohan51 I downloaded the same image as you and I did this procedure:
In the directory you will find these files:
To flash the full image you can set the command:
$sudo uuu -b emmc_all imx-boot-imx93evk-sd.bin-flash_singleboot imx-image-full-imx93evk.wic
Boot the board.
Finally:
Best regards.
Salas.
Mohan51
@Manuel_Salas ok will try to install the same and get back to you asap..Thank you
Manuel_Salas
Hello @Mohan51
In i.MX93 you need the libethosu_delegate.so, that is included in our official BSP, under /usr/lib.
I hope this can helps to you.
Best regards.
Salas.
