Error while building .img file in IMX8MM Android
1,414 次查看
Ruban1
i have attached the error below
Kindly provide the solution
Thanks and regards
Ruban
1,409 次查看
Rita_Wang
Which version ubuntu are you using? Does your host have enough RAM for compile?
