Hello.
Please look at my comments below.
1.
> Will SDK work with the OV5642 if we change minimal code?
I think - yes ; basically the SDK has examples for both MIPI CSI-2 and
parallel CSI interfaces.
2.
> Will gigabit ethernet works in SDK? We are Planning to use Ping app.
> The used Phy is KSZ9021
The loopback test does not work on the i.MX6 SDP/ SDB, but ping application
does work.
Also the following helps.
"KSZ9031 on a SabreSD based board"
< https://community.freescale.com/message/504970 >
Yuri.
