Error to execute the adb command in terminal window
hyun-moyang
Hi All,
There is an error to execute the ADB command in the terminal window to enable the multi-client input method in the android auto platform(android-11.0.0_1.1.0-AUTU) in iMX8QM MEK Board.
When I have executed the ADB command in the terminal window
 $ adb root
There is an error message in the terminal window as below,
/system/bin/sh: adb: inaccessible or not found.
When I have executed the su command in the terminal window and then, the adb command in the terminal window as below
 $su
 #adb root
Please help me to resolve the issue.
Best Regards
HM
hyun-moyang
Hi All,
Please help me to resolve this issue.
Best Regards
HM
AldoG
When you say in terminal you mean the device(i.MX)?
if this is the case, please note that adb is a tool wich runs in a host PC which the device is connected to.
Aldo.
