Error on i.MX53QSB FLT & 5V LEDs are blinking
1,490 次查看
LuisRivera
Hi, I want to know if somebody had experimented this issue.
I just introduced the SD card with the BSP of Windows compact Embedded 7 into the QSB and nothing happened even all LEDs were lit (turned on); so I decided to push the power button and sudenly FLT & 5V LEDs started to blink and the other LEDs turned off.
I took a look into the trouble shooting in hardware manual but there was anything related to this issue.
Does anybody know if there is a way to reset the board or something to solve this issue?
Note: It was the first time that I test WCE7 in the QSB.
1,267 次查看
jimmychan
Please try to contact Adeneo for support this QSB's WCE7 BSP issue.
Hi Adeneo Embedded, would you please help? Thanks in advance.
1,267 次查看
LuisRivera
Hi, I didn´t know exactly what happened with the QSB but few days ago I pushed the power buttom for 5 seconds to try to reset the board and It strated to work out; even WCE7 runed on the board.
thank you, regards
