Error is detected while using imxrt 1170
Khanajkmal
Error in final launch sequence:
Failed to execute MI command:
-target-select extended-remote localhost:10989
Error message from debugger back end:
Remote communication error. Target disconnected.: (undocumented errno 10061).
jeremyzhou
Hi @Khanajkmal ,
Before giving some advice, I was wondering if you can introduce the testing environment, such as the hardware platform, demo code, debug tool, etc.
TIC
- We are following threads for 7 weeks after the
jeremyzhou
Hi @Khanajkmal ,
TIC
