Error building Debian flexbuild using docker container
TVT
Hi!
Trying to build Debian FlexBuild using docker container with the commands:
$ cd flexbuild
$ . setup.env
$ bld docker
$ . setup.env
$ bld bsp -m imx8mpevk
Have the following result:
What am I doing wrong?
Unfortunately I couldn't find any build log to attach to my question...
The host system is Debian 12.
Thanks!
Zhiming_Liu
As your host system is Debian, you don't need to use docker. The docker should be used if your system is Ubuntu and you want to build deep learning feature.
Please delete the build_lsdk2406 folder to avoid permission issue and then build it with below three commands.
$ cd flexbuild
$ . setup.env
Zhiming
TVT
I tried to build the FlexBuild from scratch in two ways: using Debian 12 system and using Docker container. Have the following results...
Debian 12 build:
FlexBuild-D12.pngDebian 12 build
Docker build:
FlexBuild-Docker.pngDocker build
Could you give me a clue where am I wrong? Thanks!
Zhiming_Liu
You can try to create that folder in flexbuild. Did you modify the flexbuild source code?
Zhiming
TVT
Of course I did create that folder manually but there was another error which I unfortunately didn't document. And I didn't modify any part of FlexBuild source code.
Zhiming_Liu
Can you share that error?
Zhiming
TVT
Thanks! But I don't thinks that's gonna change a lot because the build process is the same. I'll try it on a clean Debian 12 system.
