Error about bitbake executionerror
zuriel921
When I run bitbake imx-image-core, some error happened, please help me , thx, here is the error report.
ERROR: rust-llvm-native-1.59.0-r0 do_compile: ExecutionError('/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/temp/run.do_compile.20175', 1, None, None)
ERROR: Logfile of failure stored in: /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/temp/log.do_compile.20175
ERROR: Task (virtual:native:/home/linux/Documents/imx-yocto-bsp/sources/poky/meta/recipes-devtools/rust/rust-llvm_1.59.0.bb:do_compile) failed with exit code '1'
here is the logfile.
DEBUG: Executing shell function do_compile
NOTE: VERBOSE=1 cmake --build /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build --target all --
[1/251] : && /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -Wl,--export-dynamic -Wl,-O3 -Wl,--gc-sections tools/llvm-jitlink/llvm-jitlink-executor/CMakeFiles/llvm-jitlink-executor.dir/llvm-jitlink-executor.cpp.o -o bin/llvm-jitlink-executor -Wl,-rpath,:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: lib/libLLVMOrcShared.a lib/libLLVMOrcTargetProcess.a lib/libLLVMSupport.a -lpthread lib/libLLVMOrcShared.a lib/libLLVMSupport.a -lrt -ldl -lpthread -lm lib/libLLVMDemangle.a && :
[2/251] : && /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -Wl,-O3 -Wl,--gc-sections tools/llvm-lipo/CMakeFiles/llvm-lipo.dir/llvm-lipo.cpp.o -o bin/llvm-lipo -Wl,-rpath,:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: lib/libLLVMARMCodeGen.a lib/libLLVMARMAsmParser.a lib/libLLVMARMDesc.a lib/libLLVMARMDisassembler.a lib/libLLVMARMInfo.a lib/libLLVMARMUtils.a lib/libLLVMAArch64CodeGen.a lib/libLLVMAArch64AsmParser.a lib/libLLVMAArch64Desc.a lib/libLLVMAArch64Disassembler.a lib/libLLVMAArch64Info.a lib/libLLVMAArch64Utils.a lib/libLLVMMipsCodeGen.a lib/libLLVMMipsAsmParser.a lib/libLLVMMipsDesc.a lib/libLLVMMipsDisassembler.a lib/libLLVMMipsInfo.a lib/libLLVMPowerPCCodeGen.a lib/libLLVMPowerPCAsmParser.a lib/libLLVMPowerPCDesc.a lib/libLLVMPowerPCDisassembler.a lib/libLLVMPowerPCInfo.a lib/libLLVMRISCVCodeGen.a lib/libLLVMRISCVAsmParser.a lib/libLLVMRISCVDesc.a lib/libLLVMRISCVDisassembler.a lib/libLLVMRISCVInfo.a lib/libLLVMX86CodeGen.a lib/libLLVMX86AsmParser.a lib/libLLVMX86Desc.a lib/libLLVMX86Disassembler.a lib/libLLVMX86Info.a lib/libLLVMObject.a lib/libLLVMOption.a lib/libLLVMSupport.a lib/libLLVMTextAPI.a lib/libLLVMCore.a lib/libLLVMBinaryFormat.a -lpthread lib/libLLVMipo.a lib/libLLVMFrontendOpenMP.a lib/libLLVMIRReader.a lib/libLLVMAsmParser.a lib/libLLVMLinker.a lib/libLLVMVectorize.a lib/libLLVMInstrumentation.a lib/libLLVMARMDesc.a lib/libLLVMARMInfo.a lib/libLLVMARMUtils.a lib/libLLVMAArch64Desc.a lib/libLLVMAArch64Info.a lib/libLLVMAArch64Utils.a lib/libLLVMRISCVDesc.a lib/libLLVMRISCVInfo.a lib/libLLVMAsmPrinter.a lib/libLLVMDebugInfoDWARF.a lib/libLLVMDebugInfoMSF.a lib/libLLVMGlobalISel.a lib/libLLVMSelectionDAG.a lib/libLLVMCodeGen.a lib/libLLVMScalarOpts.a lib/libLLVMAggressiveInstCombine.a lib/libLLVMInstCombine.a lib/libLLVMBitWriter.a lib/libLLVMTarget.a lib/libLLVMTransformUtils.a lib/libLLVMAnalysis.a lib/libLLVMObject.a lib/libLLVMTextAPI.a lib/libLLVMBitReader.a lib/libLLVMCFGuard.a lib/libLLVMProfileData.a lib/libLLVMCore.a lib/libLLVMRemarks.a lib/libLLVMBitstreamReader.a lib/libLLVMMCParser.a lib/libLLVMMCDisassembler.a lib/libLLVMMC.a lib/libLLVMBinaryFormat.a lib/libLLVMDebugInfoCodeView.a lib/libLLVMSupport.a -lrt -ldl -lpthread -lm lib/libLLVMDemangle.a && :
[3/251] : && /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -Wl,-O3 -Wl,--gc-sections tools/llvm-libtool-darwin/CMakeFiles/llvm-libtool-darwin.dir/llvm-libtool-darwin.cpp.o -o bin/llvm-libtool-darwin -Wl,-rpath,:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: lib/libLLVMBinaryFormat.a lib/libLLVMCore.a lib/libLLVMObject.a lib/libLLVMSupport.a lib/libLLVMTextAPI.a -lpthread lib/libLLVMBitReader.a lib/libLLVMCore.a lib/libLLVMRemarks.a lib/libLLVMBitstreamReader.a lib/libLLVMMCParser.a lib/libLLVMMC.a lib/libLLVMBinaryFormat.a lib/libLLVMDebugInfoCodeView.a lib/libLLVMSupport.a -lrt -ldl -lpthread -lm lib/libLLVMDemangle.a && :
[4/251] : && /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -Wl,-O3 -Wl,--gc-sections tools/llvm-link/CMakeFiles/llvm-link.dir/llvm-link.cpp.o -o bin/llvm-link -Wl,-rpath,:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: lib/libLLVMBinaryFormat.a lib/libLLVMBitReader.a lib/libLLVMBitWriter.a lib/libLLVMCore.a lib/libLLVMIRReader.a lib/libLLVMLinker.a lib/libLLVMObject.a lib/libLLVMSupport.a lib/libLLVMTransformUtils.a lib/libLLVMipo.a -lpthread lib/libLLVMBitWriter.a lib/libLLVMIRReader.a lib/libLLVMAsmParser.a lib/libLLVMLinker.a lib/libLLVMFrontendOpenMP.a lib/libLLVMScalarOpts.a lib/libLLVMAggressiveInstCombine.a lib/libLLVMInstCombine.a lib/libLLVMVectorize.a lib/libLLVMInstrumentation.a lib/libLLVMTransformUtils.a lib/libLLVMAnalysis.a lib/libLLVMObject.a lib/libLLVMBitReader.a lib/libLLVMMCParser.a lib/libLLVMTextAPI.a lib/libLLVMMC.a lib/libLLVMDebugInfoCodeView.a lib/libLLVMProfileData.a lib/libLLVMCore.a lib/libLLVMBinaryFormat.a lib/libLLVMRemarks.a lib/libLLVMBitstreamReader.a lib/libLLVMSupport.a -lrt -ldl -lpthread -lm lib/libLLVMDemangle.a && :
[5/251] : && /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -Wl,-O3 -Wl,--gc-sections tools/llvm-mc/CMakeFiles/llvm-mc.dir/llvm-mc.cpp.o tools/llvm-mc/CMakeFiles/llvm-mc.dir/Disassembler.cpp.o -o bin/llvm-mc -Wl,-rpath,:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: lib/libLLVMARMAsmParser.a lib/libLLVMAArch64AsmParser.a lib/libLLVMMipsAsmParser.a lib/libLLVMPowerPCAsmParser.a lib/libLLVMRISCVAsmParser.a lib/libLLVMX86AsmParser.a lib/libLLVMARMDesc.a lib/libLLVMAArch64Desc.a lib/libLLVMMipsDesc.a lib/libLLVMPowerPCDesc.a lib/libLLVMRISCVDesc.a lib/libLLVMX86Desc.a lib/libLLVMARMDisassembler.a lib/libLLVMAArch64Disassembler.a lib/libLLVMMipsDisassembler.a lib/libLLVMPowerPCDisassembler.a lib/libLLVMRISCVDisassembler.a lib/libLLVMX86Disassembler.a lib/libLLVMARMInfo.a lib/libLLVMAArch64Info.a lib/libLLVMMipsInfo.a lib/libLLVMPowerPCInfo.a lib/libLLVMRISCVInfo.a lib/libLLVMX86Info.a lib/libLLVMMC.a lib/libLLVMMCParser.a lib/libLLVMSupport.a -lpthread lib/libLLVMARMDesc.a lib/libLLVMARMInfo.a lib/libLLVMARMUtils.a lib/libLLVMAArch64Desc.a lib/libLLVMAArch64Info.a lib/libLLVMAArch64Utils.a lib/libLLVMRISCVDesc.a lib/libLLVMRISCVInfo.a lib/libLLVMMCDisassembler.a lib/libLLVMMC.a lib/libLLVMBinaryFormat.a lib/libLLVMDebugInfoCodeView.a lib/libLLVMSupport.a -lrt -ldl -lpthread -lm lib/libLLVMDemangle.a && :
[6/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-mca/CMakeFiles/llvm-mca.dir/CodeRegion.cpp.o -MF tools/llvm-mca/CMakeFiles/llvm-mca.dir/CodeRegion.cpp.o.d -o tools/llvm-mca/CMakeFiles/llvm-mca.dir/CodeRegion.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/CodeRegion.cpp
[7/251] : && /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -L/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/linux/Documents/imx-yocto-bsp/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 -Wl,-O3 -Wl,--gc-sections tools/llvm-cfi-verify/CMakeFiles/llvm-cfi-verify.dir/llvm-cfi-verify.cpp.o -o bin/llvm-cfi-verify -Wl,-rpath,:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: lib/libLLVMARMAsmParser.a lib/libLLVMAArch64AsmParser.a lib/libLLVMMipsAsmParser.a lib/libLLVMPowerPCAsmParser.a lib/libLLVMRISCVAsmParser.a lib/libLLVMX86AsmParser.a lib/libLLVMARMDesc.a lib/libLLVMAArch64Desc.a lib/libLLVMMipsDesc.a lib/libLLVMPowerPCDesc.a lib/libLLVMRISCVDesc.a lib/libLLVMX86Desc.a lib/libLLVMARMDisassembler.a lib/libLLVMAArch64Disassembler.a lib/libLLVMMipsDisassembler.a lib/libLLVMPowerPCDisassembler.a lib/libLLVMRISCVDisassembler.a lib/libLLVMX86Disassembler.a lib/libLLVMARMInfo.a lib/libLLVMAArch64Info.a lib/libLLVMMipsInfo.a lib/libLLVMPowerPCInfo.a lib/libLLVMRISCVInfo.a lib/libLLVMX86Info.a lib/libLLVMMC.a lib/libLLVMMCParser.a lib/libLLVMObject.a lib/libLLVMSupport.a lib/libLLVMSymbolize.a -lpthread lib/libLLVMCFIVerify.a lib/libLLVMARMDesc.a lib/libLLVMARMInfo.a lib/libLLVMARMUtils.a lib/libLLVMAArch64Desc.a lib/libLLVMAArch64Info.a lib/libLLVMAArch64Utils.a lib/libLLVMRISCVDesc.a lib/libLLVMRISCVInfo.a lib/libLLVMMCDisassembler.a lib/libLLVMSymbolize.a lib/libLLVMDebugInfoPDB.a lib/libLLVMDebugInfoMSF.a lib/libLLVMDebugInfoDWARF.a lib/libLLVMObject.a lib/libLLVMMCParser.a lib/libLLVMMC.a lib/libLLVMDebugInfoCodeView.a lib/libLLVMBitReader.a lib/libLLVMCore.a lib/libLLVMRemarks.a lib/libLLVMBitstreamReader.a lib/libLLVMTextAPI.a lib/libLLVMBinaryFormat.a lib/libLLVMSupport.a -lrt -ldl -lpthread -lm lib/libLLVMDemangle.a && :
FAILED: bin/llvm-cfi-verify
lib/libLLVMDebugInfoPDB.a(PDBSymbol.cpp.o): In function `llvm::pdb::PDBSymbol::createSymbol(llvm::pdb::IPDBSession const&, llvm::pdb::PDB_SymType) [clone .localalias.5]':
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x38): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeDimension'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x70): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeManaged'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x138): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeVTable'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x168): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeVTableShape'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x198): undefined reference to `vtable for llvm::pdb::PDBSymbolUsingNamespace'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x228): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeFunctionArg'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x258): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeFriend'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x2b8): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeTypedef'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x348): undefined reference to `vtable for llvm::pdb::PDBSymbolTypePointer'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x378): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeFunctionSig'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x3a8): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeEnum'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x3d8): undefined reference to `vtable for llvm::pdb::PDBSymbolTypeUDT'
PDBSymbol.cpp:(.text._ZN4llvm3pdb9PDBSymbol12createSymbolERKNS0_11IPDBSessionENS0_11PDB_SymTypeE+0x5e8): undefined reference to `vtable for llvm::pdb::PDBSymbolUnknown'
lib/libLLVMDebugInfoPDB.a(NativeSession.cpp.o): In function `llvm::pdb::NativeSession::parseSectionContribs() [clone .localalias.0]':
NativeSession.cpp:(.text._ZN4llvm3pdb13NativeSession20parseSectionContribsEv+0x7d): undefined reference to `llvm::pdb::DbiStream::visitSectionContributions(llvm::pdb::ISectionContribVisitor&) const'
lib/libLLVMDebugInfoPDB.a(NativeSession.cpp.o): In function `llvm::pdb::NativeSession::getModuleDebugStream(unsigned int) const':
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getModuleDebugStreamEj+0x3b): undefined reference to `llvm::pdb::DbiStream::modules() const'
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getModuleDebugStreamEj+0x49): undefined reference to `llvm::pdb::DbiModuleList::getModuleDescriptor(unsigned int) const'
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getModuleDebugStreamEj+0x51): undefined reference to `llvm::pdb::DbiModuleDescriptor::getModuleStreamIndex() const'
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getModuleDebugStreamEj+0x94): undefined reference to `llvm::pdb::ModuleDebugStreamRef::ModuleDebugStreamRef(llvm::pdb::DbiModuleDescriptor const&, std::unique_ptr<llvm::msf::MappedBlockStream, std::default_delete<llvm::msf::MappedBlockStream> >)'
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getModuleDebugStreamEj+0xaf): undefined reference to `llvm::pdb::ModuleDebugStreamRef::reload()'
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getModuleDebugStreamEj+0xcf): undefined reference to `llvm::pdb::ModuleDebugStreamRef::~ModuleDebugStreamRef()'
lib/libLLVMDebugInfoPDB.a(NativeSession.cpp.o): In function `llvm::pdb::NativeSession::addressForRVA(unsigned int, unsigned int&, unsigned int&) const [clone .localalias.13]':
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession13addressForRVAEjRjS2_+0xd8): undefined reference to `llvm::pdb::DbiStream::getSectionHeaders() const'
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession13addressForRVAEjRjS2_+0x1a5): undefined reference to `llvm::pdb::DbiStream::getSectionHeaders() const'
lib/libLLVMDebugInfoPDB.a(NativeSession.cpp.o): In function `llvm::pdb::NativeSession::getRVAFromSectOffset(unsigned int, unsigned int) const [clone .part.292]':
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getRVAFromSectOffsetEjj.part.292+0x47): undefined reference to `llvm::pdb::DbiStream::getSectionHeaders() const'
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getRVAFromSectOffsetEjj.part.292+0x91): undefined reference to `llvm::pdb::DbiStream::getSectionHeaders() const'
lib/libLLVMDebugInfoPDB.a(NativeSession.cpp.o): In function `llvm::pdb::NativeSession::getInjectedSources() const [clone .localalias.30]':
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession18getInjectedSourcesEv+0xed): undefined reference to `llvm::pdb::NativeEnumInjectedSources::NativeEnumInjectedSources(llvm::pdb::PDBFile&, llvm::pdb::InjectedSourceStream const&, llvm::pdb::PDBStringTable const&)'
lib/libLLVMDebugInfoPDB.a(NativeSession.cpp.o): In function `llvm::pdb::NativeSession::getNativeGlobalScope() const [clone .localalias.3]':
NativeSession.cpp:(.text._ZNK4llvm3pdb13NativeSession20getNativeGlobalScopeEv+0x82): undefined reference to `llvm::pdb::NativeExeSymbol::NativeExeSymbol(llvm::pdb::NativeSession&, unsigned int)'
lib/libLLVMDebugInfoPDB.a(PDBFile.cpp.o): In function `llvm::pdb::PDBFile::~PDBFile() [clone .localalias.11]':
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFileD2Ev+0x273): undefined reference to `llvm::pdb::DbiStream::~DbiStream()'
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFileD2Ev+0x3bc): undefined reference to `llvm::pdb::GlobalsStream::~GlobalsStream()'
lib/libLLVMDebugInfoPDB.a(PDBFile.cpp.o): In function `llvm::pdb::PDBFile::getPDBDbiStream() [clone .localalias.5]':
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile15getPDBDbiStreamEv+0xac): undefined reference to `llvm::pdb::DbiStream::DbiStream(std::unique_ptr<llvm::BinaryStream, std::default_delete<llvm::BinaryStream> >)'
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile15getPDBDbiStreamEv+0xca): undefined reference to `llvm::pdb::DbiStream::reload(llvm::pdb::PDBFile*)'
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile15getPDBDbiStreamEv+0xef): undefined reference to `llvm::pdb::DbiStream::~DbiStream()'
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile15getPDBDbiStreamEv+0x12b): undefined reference to `llvm::pdb::DbiStream::~DbiStream()'
lib/libLLVMDebugInfoPDB.a(PDBFile.cpp.o): In function `llvm::pdb::PDBFile::getPDBSymbolStream()':
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile18getPDBSymbolStreamEv+0x86): undefined reference to `llvm::pdb::DbiStream::getSymRecordStreamIndex() const'
lib/libLLVMDebugInfoPDB.a(PDBFile.cpp.o): In function `llvm::pdb::PDBFile::getPDBPublicsStream()':
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile19getPDBPublicsStreamEv+0x86): undefined reference to `llvm::pdb::DbiStream::getPublicSymbolStreamIndex() const'
lib/libLLVMDebugInfoPDB.a(PDBFile.cpp.o): In function `llvm::pdb::PDBFile::getPDBInfoStream() [clone .localalias.6]':
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile16getPDBInfoStreamEv+0xbc): undefined reference to `llvm::pdb::InfoStream::InfoStream(std::unique_ptr<llvm::BinaryStream, std::default_delete<llvm::BinaryStream> >)'
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile16getPDBInfoStreamEv+0xd7): undefined reference to `llvm::pdb::InfoStream::reload()'
lib/libLLVMDebugInfoPDB.a(PDBFile.cpp.o): In function `llvm::pdb::PDBFile::safelyCreateNamedStream(llvm::StringRef) [clone .localalias.0]':
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile23safelyCreateNamedStreamENS_9StringRefE+0x73): undefined reference to `llvm::pdb::InfoStream::getNamedStreamIndex(llvm::StringRef) const'
lib/libLLVMDebugInfoPDB.a(PDBFile.cpp.o): In function `llvm::pdb::PDBFile::getInjectedSourceStream()':
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile23getInjectedSourceStreamEv+0xfc): undefined reference to `llvm::pdb::InjectedSourceStream::InjectedSourceStream(std::unique_ptr<llvm::msf::MappedBlockStream, std::default_delete<llvm::msf::MappedBlockStream> >)'
PDBFile.cpp:(.text._ZN4llvm3pdb7PDBFile23getInjectedSourceStreamEv+0x11c): undefined reference to `llvm::pdb::InjectedSourceStream::reload(llvm::pdb::PDBStringTable const&)'
lib/libLLVMDebugInfoPDB.a(PublicsStream.cpp.o): In function `llvm::pdb::PublicsStream::reload()':
PublicsStream.cpp:(.text._ZN4llvm3pdb13PublicsStream6reloadEv+0x264): undefined reference to `llvm::pdb::GSIHashTable::read(llvm::BinaryStreamReader&)'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::getSourceFileById(unsigned int) const':
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache17getSourceFileByIdEj+0x37): undefined reference to `vtable for llvm::pdb::NativeSourceFile'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `void std::vector<llvm::pdb::NativeLineNumber, std::allocator<llvm::pdb::NativeLineNumber> >::_M_realloc_insert<llvm::pdb::NativeLineNumber const&>(__gnu_cxx::__normal_iterator<llvm::pdb::NativeLineNumber*, std::vector<llvm::pdb::NativeLineNumber, std::allocator<llvm::pdb::NativeLineNumber> > >, llvm::pdb::NativeLineNumber const&)':
SymbolCache.cpp:(.text._ZNSt6vectorIN4llvm3pdb16NativeLineNumberESaIS2_EE17_M_realloc_insertIJRKS2_EEEvN9__gnu_cxx17__normal_iteratorIPS2_S4_EEDpOT_[_ZNSt6vectorIN4llvm3pdb16NativeLineNumberESaIS2_EE17_M_realloc_insertIJRKS2_EEEvN9__gnu_cxx17__normal_iteratorIPS2_S4_EEDpOT_]+0x82): undefined reference to `vtable for llvm::pdb::NativeLineNumber'
SymbolCache.cpp:(.text._ZNSt6vectorIN4llvm3pdb16NativeLineNumberESaIS2_EE17_M_realloc_insertIJRKS2_EEEvN9__gnu_cxx17__normal_iteratorIPS2_S4_EEDpOT_[_ZNSt6vectorIN4llvm3pdb16NativeLineNumberESaIS2_EE17_M_realloc_insertIJRKS2_EEEvN9__gnu_cxx17__normal_iteratorIPS2_S4_EEDpOT_]+0x120): undefined reference to `vtable for llvm::pdb::NativeLineNumber'
SymbolCache.cpp:(.text._ZNSt6vectorIN4llvm3pdb16NativeLineNumberESaIS2_EE17_M_realloc_insertIJRKS2_EEEvN9__gnu_cxx17__normal_iteratorIPS2_S4_EEDpOT_[_ZNSt6vectorIN4llvm3pdb16NativeLineNumberESaIS2_EE17_M_realloc_insertIJRKS2_EEEvN9__gnu_cxx17__normal_iteratorIPS2_S4_EEDpOT_]+0x1d8): undefined reference to `vtable for llvm::pdb::NativeLineNumber'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::getOrCreateCompiland(unsigned int) [clone .localalias.1]':
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCache20getOrCreateCompilandEj+0xe4): undefined reference to `llvm::pdb::DbiStream::modules() const'
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCache20getOrCreateCompilandEj+0xf4): undefined reference to `llvm::pdb::DbiModuleList::getModuleDescriptor(unsigned int) const'
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCache20getOrCreateCompilandEj+0x165): undefined reference to `llvm::pdb::NativeCompilandSymbol::NativeCompilandSymbol(llvm::pdb::NativeSession&, unsigned int, llvm::pdb::DbiModuleDescriptor)'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::SymbolCache(llvm::pdb::NativeSession&, llvm::pdb::DbiStream*)':
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCacheC2ERNS0_13NativeSessionEPNS0_9DbiStreamE+0x1af): undefined reference to `llvm::pdb::DbiStream::modules() const'
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCacheC2ERNS0_13NativeSessionEPNS0_9DbiStreamE+0x1b7): undefined reference to `llvm::pdb::DbiModuleList::getModuleCount() const'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::getOrCreateSourceFile(llvm::codeview::FileChecksumEntry const&) const [clone .localalias.0]':
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache21getOrCreateSourceFileERKNS_8codeview17FileChecksumEntryE+0x165): undefined reference to `llvm::pdb::NativeSourceFile::NativeSourceFile(llvm::pdb::NativeSession&, unsigned int, llvm::codeview::FileChecksumEntry const&)'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::findFunctionSymbolBySectOffset(unsigned int, unsigned int) [clone .localalias.4]':
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCache30findFunctionSymbolBySectOffsetEjj+0xbd3): undefined reference to `llvm::pdb::ModuleDebugStreamRef::~ModuleDebugStreamRef()'
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCache30findFunctionSymbolBySectOffsetEjj+0xc80): undefined reference to `llvm::pdb::NativeFunctionSymbol::NativeFunctionSymbol(llvm::pdb::NativeSession&, unsigned int, llvm::codeview::ProcSym const&, unsigned int)'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::findPublicSymbolBySectOffset(unsigned int, unsigned int) [clone .localalias.3]':
SymbolCache.cpp:(.text._ZN4llvm3pdb11SymbolCache28findPublicSymbolBySectOffsetEjj+0xcf6): undefined reference to `llvm::pdb::NativePublicSymbol::NativePublicSymbol(llvm::pdb::NativeSession&, unsigned int, llvm::codeview::PublicSym32 const&)'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::findLineTable(unsigned short) const [clone .localalias.2]':
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache13findLineTableEt+0xce6): undefined reference to `llvm::pdb::ModuleDebugStreamRef::~ModuleDebugStreamRef()'
lib/libLLVMDebugInfoPDB.a(SymbolCache.cpp.o): In function `llvm::pdb::SymbolCache::findLineNumbersByVA(unsigned long, unsigned int) const':
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache19findLineNumbersByVAEmj+0x205): undefined reference to `llvm::pdb::ModuleDebugStreamRef::findChecksumsSubsection() const'
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache19findLineNumbersByVAEmj+0x2e5): undefined reference to `llvm::pdb::NativeLineNumber::NativeLineNumber(llvm::pdb::NativeSession const&, llvm::codeview::LineInfo, unsigned int, unsigned int, unsigned int, unsigned int, unsigned int, unsigned int)'
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache19findLineNumbersByVAEmj+0x309): undefined reference to `vtable for llvm::pdb::NativeLineNumber'
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache19findLineNumbersByVAEmj+0x63f): undefined reference to `llvm::pdb::NativeEnumLineNumbers::NativeEnumLineNumbers(std::vector<llvm::pdb::NativeLineNumber, std::allocator<llvm::pdb::NativeLineNumber> >)'
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache19findLineNumbersByVAEmj+0x736): undefined reference to `llvm::pdb::ModuleDebugStreamRef::~ModuleDebugStreamRef()'
SymbolCache.cpp:(.text._ZNK4llvm3pdb11SymbolCache19findLineNumbersByVAEmj+0x750): undefined reference to `vtable for llvm::pdb::NativeLineNumber'
collect2: error: ld returned 1 exit status
[8/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/DispatchStatistics.cpp.o -MF tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/DispatchStatistics.cpp.o.d -o tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/DispatchStatistics.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/Views/DispatchStatistics.cpp
[9/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-mca/CMakeFiles/llvm-mca.dir/CodeRegionGenerator.cpp.o -MF tools/llvm-mca/CMakeFiles/llvm-mca.dir/CodeRegionGenerator.cpp.o.d -o tools/llvm-mca/CMakeFiles/llvm-mca.dir/CodeRegionGenerator.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/CodeRegionGenerator.cpp
[10/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/BottleneckAnalysis.cpp.o -MF tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/BottleneckAnalysis.cpp.o.d -o tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/BottleneckAnalysis.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/Views/BottleneckAnalysis.cpp
[11/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-mca/CMakeFiles/llvm-mca.dir/PipelinePrinter.cpp.o -MF tools/llvm-mca/CMakeFiles/llvm-mca.dir/PipelinePrinter.cpp.o.d -o tools/llvm-mca/CMakeFiles/llvm-mca.dir/PipelinePrinter.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/PipelinePrinter.cpp
[12/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/InstructionInfoView.cpp.o -MF tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/InstructionInfoView.cpp.o.d -o tools/llvm-mca/CMakeFiles/llvm-mca.dir/Views/InstructionInfoView.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/Views/InstructionInfoView.cpp
[13/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-mca/CMakeFiles/llvm-mca.dir/llvm-mca.cpp.o -MF tools/llvm-mca/CMakeFiles/llvm-mca.dir/llvm-mca.cpp.o.d -o tools/llvm-mca/CMakeFiles/llvm-mca.dir/llvm-mca.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-mca/llvm-mca.cpp
[14/251] /home/linux/Documents/imx-yocto-bsp/build/tmp/hosttools/g++ -DGTEST_HAS_RTTI=0 -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/tools/llvm-lto2 -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-lto2 -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/build/include -I/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/include -isystem/home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -fPIC -fno-semantic-interposition -fvisibility-inlines-hidden -Werror=date-time -Wall -Wextra -Wno-unused-parameter -Wwrite-strings -Wcast-qual -Wno-missing-field-initializers -pedantic -Wno-long-long -Wimplicit-fallthrough -Wno-maybe-uninitialized -Wno-noexcept-type -Wdelete-non-virtual-dtor -Wno-comment -Wmisleading-indentation -fdiagnostics-color -ffunction-sections -fdata-sections -DNDEBUG -fno-exceptions -fno-rtti -std=c++14 -MD -MT tools/llvm-lto2/CMakeFiles/llvm-lto2.dir/llvm-lto2.cpp.o -MF tools/llvm-lto2/CMakeFiles/llvm-lto2.dir/llvm-lto2.cpp.o.d -o tools/llvm-lto2/CMakeFiles/llvm-lto2.dir/llvm-lto2.cpp.o -c /home/linux/Documents/imx-yocto-bsp/build/tmp/work/x86_64-linux/rust-llvm-native/1.59.0-r0/rustc-1.59.0-src/src/llvm-project/llvm/tools/llvm-lto2/llvm-lto2.cpp
ninja: build stopped: subcommand failed.
WARNING: exit code 1 from a shell command.
Harvey021
Hi @zuriel921
Please share which BSP, machine and backend you are building.
Did you install all necessary host packages on your build machine?
Harvey
Harvey021
Hi @zuriel921
Harvey
zuriel921
repo init -u https://source.codeaurora.org/external/imx/imx-manifest  -b imx-linux-hardknott -m imx-5.10.72-2.2.0.xml
the yocto release, and machine name is IMX8M PLUS QUAD, chip model is MIMX8ML8DVNLZAB, can you tell me which packages need to be installed, thanks
Harvey021
Hi @zuriel921
Host packages for LF5.10.72:
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat cpio python python3 python3-pip python3-pexpect \
xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev \
pylint3 xterm rsync curl
Please follow up the i.MX_Yocto_Project_User's_Guide.pdf
https://www.nxp.com/webapp/Download?colCode=L5.10.72_2.2.0_LINUX_DOCS
Harvey
zuriel921
OK, thanks, I"ll try it.
