Encrypted storage with TrustZone
已解决
跳至解决方案
2,666 次查看
brucezhao
Fresh Out Contributor
    AN12714 (i.MX Encrypted Storage Using CAAM Secure Keys) document describes Encrypted storage with CAAM.
    My question is that if I want to use CSU(Central Security Unit) to limit only OP-TEE can access CAAM, then CAAM can not be accessed by Normal world directly. I mean how to implement encrypted storage with OP-TEE, which uses OTPMK as root key by CAAM.
    Thanks.
1 解答
2,653 次查看
Harvey021
Hi @brucezhao
OP-TEE itself is secure world, which should be able to access CAAM. AN12714 here mainly uses the kernel module DM-Crypt, which uses CAAM's secure key to implement disk encryption, and does not implement the requirements you mentioned.
Harvey
Harvey
在原帖中查看解决方案
2 回复数
2,638 次查看
brucezhao
Hi Harvey, I got it. Thank you for your reply.
2,654 次查看
Harvey021
Hi @brucezhao
Harvey
Harvey
